Where are our flasher relays located?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 0uTkAsT, Jan 30, 2012.
  1. Jan 30, 2012 at 10:34 AM
    0uTkAsT
    0uTkAsT [OP] Low Speed High Drag
    Josh
    Gilbert, AZ
    rock-flinging dad rig
    Stuff that makes it easier to run over other stuff
    Simple enough question... I hear it clicking under my dash but I can't seem to find it. I feel like a moron. I need to swap it out for my LED compatible flasher. Can anyone point me in the right direction? Thanks!
  2. Jan 30, 2012 at 4:43 PM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Under the dash attached to the side of the fuse panel. Turn flashers on and feel around. You will feel it clicking.
  3. May 12, 2012 at 12:11 PM
    enisi
    enisi New Member
    01 Emerald Green Crew Cab
    Thank you, My Problem: the blinker stops blinking when brakes are applied. I could not find the flasher relay to replace it. Thanks for the post... problem was fixed in 5! :)
  4. May 12, 2012 at 2:12 PM
    dlg636
    dlg636 Active Member
    Darrin
    Honolulu, Hawaii
    4x4 Tacoma w/all the goodies
    DR front coils and rear shocks, deaver springs, load leveling airbags, k&n intake, JBA hedders and exhaust,Unichip power chip, URD short shifter, onboard air compressor, upgraded power inverter (1000W put in stock inverters location) budbuilt traction bar, warn transformer winch mount and warn winch, HID headlights and foglights, full LED bulb conversion, LED bed lights, full stereo system with GPS and they all roll on 16x8 black steel rock crusher and 285/75R16 BFG KM2's.
    its located behind the fuse box. you need to take out the fuse box and its right there. i needed to find mines to do the same thing you're doing. change flasher relay for led flasher relay. hope this helps.
  5. May 12, 2012 at 6:41 PM
    0uTkAsT
    Josh
    Gilbert, AZ
    I didn't have to remove the fuse box to get mine out, just a lot of swearing while upside down with my skull holding in the clutch pedal just so I could see what I was working on.
  6. Nov 19, 2012 at 7:17 PM
    caan
    caan New Member
    ray
    nova scotia
    tacoma sr5
    were do you get led flashers im in canada i can order them from USA
