Where are the winch bumpers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Member1Zillion, Mar 22, 2016.
  1. Jan 27, 2017 at 1:15 PM
    #421
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
  2. Jan 29, 2017 at 9:52 AM
    #422
    Maine 110
    Maine 110 Member
    Jesse
    under a rock
    2022- 4cyl auto base
    under construction
    Second Gen Trail Gear bumper on a 16?
    I already posted this as its own thread but was advised to ask it here in the front bumper thread. Sorry for the double post... Also I have done some searching here and elsewhere and don't see anyone talking about this, maybe I am not searching with the right questions, so please don't flame me for not searching.
    Question is will a second generation bumper/ bull bar fit a third generation truck. I have Trail Gear front and rear bumpers and would like to know if they will fit a 2016 third gen truck? I spent some time with a tape measure and it looks like the front will work, Trail Gear stuff is not fit tight to the bodywork like some of the higher end bumpers. From what I understand the frame on the second generation trucks are the same as the third generation.
    Thanks for any help.
    Jesse
    Recovering Land Rover Owner
  3. Jan 29, 2017 at 10:47 AM
    #423
    C4 Fabrication
    C4 Fabrication Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    I don't know of anyone who has tried this yet, maybe you should be the first so everyone else will know if it works? My immediate guess is that the bumpers will bolt onto the frame because the mounts are the same, but they will be so far from fitting the body shape that it wouldn't work or it would look terrible. The rear bumper may also contact the tailgate when it opens because the tailgate has so much convex curve to it compared to the 2nd gen gate.
  4. Jan 29, 2017 at 12:26 PM
    #424
    Maine 110
    Maine 110 Member
    Jesse
    under a rock
    under construction
    I just spent some time with a tape measure and am going to give it a try. It looks like the biggest challenge is the height and protrusion of the grill on the 16'. I agree the mounting points seem to be identical, it is going to come down to clearance / aesthetics with the body. The Trail Gear is not a highly fit unit anyway and is about as minimal as you can get for actual bumper structure so it should be interesting to see how it looks....
  5. Jan 30, 2017 at 8:55 AM
    #425
    monkeyevil
    monkeyevil Victory 4x4
    Daryl
    Kalamazoo, MI
    I just happen to know of something in the works. I would guess we will have availability in the next 4-6 weeks.
    Here's what I can tell you. American made by a respected manufacturer of Jeep Armor. Laser cut, CNC bent, hand welded.
    This is a leak of prototype #2. Some changes in the works and then we will make tube work decisions :)
    batfeet, 0uTkAsT and MESO like this.
  6. Feb 5, 2017 at 10:04 AM
    #426
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Hey everyone, we are hosting a Lo-Pro winch bumper giveaway on Instagram. Check it out!
    mcharfauros and 0uTkAsT like this.
  7. Feb 21, 2017 at 6:51 AM
    #427
    three zero seven
    three zero seven Well-Known Member
    2016 TRD ORDCLB
    I stopped following this thread for a little while after my bumper was delivered, so I hope I'm not asking a question that has already been asked. I have the Aluminum CBI Off Road bumper that weighs somewhere in the ballpark of 60lbs. After installing it my front end is sagging about an inch lower than it was with the factory bumper. My question is if I installed 5100s around the truck, could I lift the truck about an inch in the back and bring the front up high enough to maintain the factory-ish looking camber? I don't want my ass end sagging too much when I tow a trailer. Has anyone gone this route?
    2k4Taco likes this.
  8. Feb 21, 2017 at 7:15 AM
    #428
    Triggerhappy
    Triggerhappy Well-Known Member
    Jake
    Denver
    2019 T4Runner ORP
    It never ends
    Anyone have the weight difference of the CBI T3 aluminum vs the steel? Is the $300 worth it?
  9. Feb 21, 2017 at 7:19 AM
    #429
    wjrichardson
    wjrichardson Well-Known Member
    WI
    2017 TRD/OR/AC
    Per CBI website the steel T3 with grill guard is 118lbs and per the post above you the aluminum version is ~60lbs.
    Triggerhappy[QUOTED] likes this.
  10. Feb 21, 2017 at 7:20 AM
    #430
    Triggerhappy
    Jake
    Denver
    2019 T4Runner ORP
    It never ends
    I looked, I must be a little slow this morning. Thanks! I would say the $300 would be worth it, especially without the light guards.
  11. Feb 21, 2017 at 7:22 AM
    #431
    wjrichardson
    WI
    2017 TRD/OR/AC
    No problem. IMO a ~50% weight reduction is worth $300 but like everything in life, "it depends".
  12. Feb 21, 2017 at 7:36 AM
    #432
    three zero seven
    2016 TRD ORDCLB
    Per an e-mail from the CBI sales team I received when I was researching which bumper I wanted.
    "Regarding weight you are around 125 lbs for the full grill protection option in steel and the aluminum option is around 60 lbs."
    The weight savings for me was worth the extra money. (of course I had an insurance check paying for a good portion of the bumper and install)
    I was also told over the phone by these guys that the steel would hold up better to jagged rocks and things like that vs the slightly thicker aluminum. So for more of a rock crawler application the steel would be the better option. For what I do in my truck, aluminum is more than strong enough.
  13. Feb 21, 2017 at 10:35 AM
    #433
    Logan.spencer
    Logan.spencer Well-Known Member
    Logan
    Southern VT
    '18 TRD OR DCSB Cement Manual
    2018 TRD OR DCSB 6 Speed MT Magnaflow Catback CBI T3 Front bumper RCI Skids (front, trans, t-case) RCI Rear Bumper (custom swivel recovery points) Rocky Road SuperSliders ARE Overland cap with area lighting Rigid SRQ backup lights Rigid DSS ditch lights Baja Designes 20" single row Baja Designs squadron sport fogs Icon Stage 9 SwitchPros power system ...i may be forgetting something...
    im more worried about stupid people in parking lots, deer, and trees on the trails
  14. Feb 21, 2017 at 12:07 PM
    #434
    DarthMinnow
    DarthMinnow Well-Known Member
    '16 Tacoma TRD Sport 4x4 AT
    Than I would opt for a large steel bumper such as I have an ARB summit bumper. 170 pounds of steel, deer and trees will get destroyed running into it.
  15. Feb 21, 2017 at 12:18 PM
    #435
    Logan.spencer
    Logan
    Southern VT
    I'm good without the ARB thanks!
  16. Feb 21, 2017 at 4:14 PM
    #436
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    https://www.tacomaworld.com/threads/2016-tacoma-cbi-offroad-fab-t3-front-bumper.461580/
    im surprised more people haven't commented or looked at this thread I made... its a full install how to for the CBI front bumper install... a lot of good tips and tricks for the hardware and what exactly goes where... its helped a few people by allowing them to see if anything is missing... thus preventing stoppages or issues with the install...
    mauidogg likes this.
  17. Feb 21, 2017 at 10:36 PM
    #437
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    Yup there's a few of us and we are more than happy to answer questions
    Danactive[QUOTED] likes this.
  18. Feb 22, 2017 at 12:17 PM
    #438
    bilplat
    bilplat Simply Driving Into Mordor
    Bill
    Denver, CO
    '17 White A/T 4x4 TRD OR DCSB
    ARE Hard Top
    Hey all. I've collected info on 7 bumpers that I'm deciding between. They are all of similar geometry, with slim form factors that follow the curves of the stock grill but still require a little cutting. They all offer increased approach angles over stock, with varying amounts of added or subtracted length to the overall truck. Other bumpers that are close to this form, but not quite what I'm looking for, are provided by great companies such as C4, Relentless, All-Pro, SOS, and countless others. I'm not trying to bash on these companies, just trying to provide info on bumpers that fit my preference. I'm set on a steel bumper, so I've just included info on those (a couple of the following bumpers are also available in aluminum, for those interested). Without further ado, here are the bumpers (in no particular order):
    Pelfreybilt
    http://www.pelfreybilt.com/product/16-tacoma-steel-front-plate-bumper/
    Ranges from $950 (bare, no hoops, 105 lb) to $1350 (Line-X'd, full hoops, 125 lb). Fog light cutouts appear square; may or may not be compatible with stock fog lights. Ships from Lemon Grove, CA.
    InSain Fab
    http://www.insainfab.com/
    https://www.tacomaworld.com/threads/insain-fabrication.370283/
    http://toyteclifts.3dcartstores.com/Insain-Fabrication-Front-Tacoma-Bumper_p_1505.html
    Starts at $1300 (bare, no extra lights). Fog light cutouts are compatible with stock fog lights. Can be bought through ToyTec; ToyTec and InSain are located near Thornton, CO. I am drawn to InSain because they are the only manufacturer on this list near the Denver area. It appears that this bumper does not extend too much, if at all, beyond the stock length; something to keep in mind for frontal collisions.
    Demello Offroad
    http://demello-offroad.com/demello-off-road-tacoma-low-profile-baja-front-bumper-16-17
    http://demello-offroad.com/demello-off-road-tacoma-baja-front-bumper-16-17
    The Baja and Baja Low Profile bumpers are priced the same. The only difference (as far as I can tell from the pictures) is that the Low Profile bumper has bull bars at a lower angle. They range from $1275 (bare, no extra lights) to $1879 (powdercoated, Pro lights). Stock fogs do not fit. Shipped from Riverside, CA. From my research it is apparent that Demello Off Road produces a quality bumper, not only in terms of outer looks, but also in terms of a well-engineered support structure behind the bumper. More into my personal preferences: I dislike branding and should I go forward with Demello, I will probably end up covering the "DO" with my license plate.
    Baja Pics:
    Baja Low Profile Pics:
    CBI Offroad T3
    http://www.cbioffroadfab.com/products/3rd-gen-toyota-tacoma/t3-front-bumper/
    http://www.cbioffroadfab.com/products/3rd-gen-toyota-tacoma/t3-front-bumper-with-center-grill-guard/
    http://www.cbioffroadfab.com/produc...a/t3-front-bumper-with-full-grill-protection/
    Ranges from $1000 (bare, no hoop, 105 lb) to $1275 (powdercoated, 3 loops, 130lb). Fog light cutouts are circular and compatible with stock fog lights. Ships from Idaho Falls, ID. The bottom of the grill is boxed (as opposed to tabbed) for better strength, allowing you to Hi-Lift at any point without deflection into the grill or other components.
    Dissent Off Road
    https://www.tacomaworld.com/threads/dissent-off-road-2016-inferno-build.437413/
    Most of this info is either from this thread or his build thread. I haven't heard that he's put this into production yet, but I saw that he said it'd be around $1100. It is modular (meaning you can get a two-tone finish) and about 85 lb. I also saw a pic of a bolt-on bull bar that covers abut half the grill. It leaves the factory fogs in place while adding 6" lights.
    Dobinsons
    https://www.tacomaworld.com/threads/dobinsons-16-taco-front-winch-bumper.456675/
    Price is $1150 (bare, 4" LED fogs included, turn signal lights included, 119 lb). This is the only bumper on this list that includes cutouts for turn signals, which seems redundant to me, since the in-headlight ones aren't lost.
    Victory 4x4
    https://www.tacomaworld.com/threads/victory-4x4-bumper-final-prototype.475512/
    Another bumper that has yet to hit production. Not a lot of info besides the pics, which were taken from TW. Victory is located in Portage, MI.
    Let me know if any of this info is wrong or if you could fill in any missing info. If you know of another bumper that fits in this post, let me know.
  19. Feb 22, 2017 at 10:14 PM
    #439
    mauidogg
    16 DCSB TRDOR
    pelfrey, Demello, cbi bumpers actually protrude less than the stock bumper, better angle of departure. The insain fab bumper protrudes the least.
    Another thing is the CBI bumper has a better mount for the very bottom of the bumper. It is boxed full in instead of just tabs. I know the C4 bumper has just tabs but heard they were looking into boxing it in so that if you were to hilift the front it wouldnt deflect into the grille. Not sure if any of the others box in the bottom.
  20. Mar 6, 2017 at 12:52 PM
    #440
    Logan.spencer
    Logan
    Southern VT
    can you post some more pics of this setup? this is the exact thing im looking at and i have a white truck.
