Where are your vibrations??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Voos, Aug 1, 2009.
  1. Aug 1, 2009 at 3:01 PM
    Voos
    Voos [OP] Well-Known Member
    Eric
    Albuquerque, NM
    Dbl Cab SB TRD Off Road
    Icon CO's, Total Chaos UCA's All-Pro 3" leaf packs w/ U bolt flip +Timbren, Rear Bilstein 5100's, Dick Cepek DC1's Black, 285/70R17 BFG ATko, ProDryS drop in, Dynomax Super Turbo
    OK guys.. I know vibes are common after lift, but I'm trying to figure out what vibes are the norm and what most experience...
    My setup: Icon Coilovers set @ 2.5, Deaver 10 leaf(though only providing just under an inch of lift)And Billy 5100's in the rear.. I have installed both 3 degree shims and a carrier bearing drop.
    My Problems: Vibrations at 15-20 are minuscule and not really a complaint, However around 50-60 then again at 75+ I get some pretty good vibes I really don't like, which basically feels like out of balance tires.
    Is this common vibration?
  2. Aug 1, 2009 at 5:00 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    My only vibes are at 15mph and I think its just the tread on my tires. I still have a little shimmy in my steering wheel @ 45 but its not really noticeable unless you let go and watch it. I have a diff drop, but no carrier bearing drop (YET).
  3. Aug 1, 2009 at 5:09 PM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Is the whole truck vibing or just the steering wheel?
    If it is the steering wheel might want to have your rotors checked or have your wheels balanced. If it balancing issues get them road forced balanced.
    Are your wheels hub centric or lug centric?
  4. Aug 1, 2009 at 5:18 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    I have vibes on take off till about 30. I have a C/B drop but no shims. I'm Installing the shims monday. But after 30 I'm goog nothing all the way up to 90mph and the steering is fine. Did you try taking off the C/B drop to see if it gets better?
  5. Aug 1, 2009 at 5:36 PM
    Voos
    Eric
    Albuquerque, NM
    No movement in the steering wheel.. Its an entire truck vibe! Stock wheels...
    The vibe was there before the CB drop.. Still exists. The truck only has 3k on it.
  6. Sep 17, 2009 at 1:52 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Did installing your shims eliminate yoru vibe to 30mph?
    I sometimes have a vibe on acceleration and decleration below 40mph...other days its fine? I had the diff drop, but pulled that and it stopped but somedays its back...when it does happen if I put it in N its still there, if I lock in 4*4 it goes away? Or if I play with the steering wheel by swerving back and forth its not there and feels like the right front tire is the cause because it gets better..Your thoughts? I'm thinking alignment is off slightly off cause of the OEM UCAs are still on, but it rides fine to me up to 90mph. Bumpy roads sometimes cause this to happen, WI roads by me are pretty rough so its hard to tell if something is wrong.
    My ABS light is on, I pulled the wire on install...but that shouldn't be doing anything for on off vibes right?
  7. Sep 17, 2009 at 1:54 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    I have no vibes at all, thankfully ;)
  8. Sep 17, 2009 at 4:08 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    almost the same set up, I get some low speed like 15mph when coming to a stop. might be my tires or the road or that tranny mount TSB .. I put 2* shims on mine (guy at deaver sold em to me) and that took out the higher speed vibes. I live with it , it isn't bad ... but that damn clunking after I stop sometimes is STILL pissin me off.
  9. Sep 17, 2009 at 4:33 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I get some at take off to 15mph but I think it the lugs on the tires, and my steering wheel wiggles abit at hwy speeds it drives me nuts
  10. Sep 17, 2009 at 4:37 PM
    Faskev
    Faskev Well-Known Member
    When I first installed the Toytec Ultimate lift with the included diff drop and rear axle shims I had a take-off vibe but I ordered the Carrier bearing drop and now I'm vibe free!
  11. Sep 17, 2009 at 5:37 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    I was going to order that too but got the diff drop instead o well mines so little its no biggie
    Roughriders suck:D
  12. Sep 18, 2009 at 5:22 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Did you guys have a constant vibe? Mine seems to come and go.
  13. Sep 18, 2009 at 5:09 PM
    Faskev
    Lol! I also have the diff drop along with the shims and carrier bearing spacer.
  14. Sep 18, 2009 at 9:28 PM
    thomasr1950
    thomasr1950 19 Tacoma TRD Off Road
    central us
    Take it to your dealer. Make sure they have the right adapter when they do the balance. Otherwise it will do no good. I had vibration from 55 +, dealer did a road balance, didn't fix the issue, then they realized they didn't use the right adapter.
  15. Sep 18, 2009 at 9:36 PM
    Gsquare
    Gsquare The G stands for smooth
    GG
    Lone Star State
    2018 - TRD Off Road 4x4 - Cement / Graphite - DCSB
    ReadyLIFT 3/2 Lift Kit, T-Force TRD Black Satin Spoke Wheels, OEM TRD Red/Black Resin Center Wheel Hub Covers, Toyo P285/70R17 Open Country AT's, SpiderTrax 1.25 F/R Wheel Spacers, Blackout Pkg: Tailgate Letters, Badges and Tailpipe Extension, Qi Wireless Charging, LED Bed Lights, Power Tailgate Lock, Shark Running Boards, Weathertech Floor Mats, U.S. Airforce Decal Drivers Side Rear Window, MESO Gasshole Fuel Cap Holder, OEM Trailer Hitch Cap
    No vibes here at any speed with the Toytec ULK and diff drop. But, I'm still running stock tires and wheels -- P265/65R/17.
    Sounds like alignment.
    Check Chris4x4 threads for exact toe and camber specs.
  16. Sep 18, 2009 at 11:04 PM
    tacobale
    tacobale Well-Known Member
    1K miles and 65 mph + vibe from day one. This truck has not impressed me much except in a bad way! I may have made a mistake buying it. The good news is trade in is more than I paid for it! Might have a Nissan soon. Had 3 Nissans prior with no problems. Should have stuck with them.
  17. Sep 18, 2009 at 11:39 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I just installed wheel spacers at 1¼" and at 70mph I get some shimmy in the steering wheel. Not sure if I have to take them off and try it again or what. No lift on my truck.
    Only thing is the front wheels were fused on as alloys often do, and kicking them did nothing to loosen them, so I gently dropped the truck down on them to break the seal with the lugs off and that did the trick.
    Any clues?
  18. Sep 19, 2009 at 2:23 PM
    Bugsey
    Bugsey Member
    Ontario
    08 Access Cab SR5
    Yep I got 'em. This is a big change from driving a 4Runner for 15 years. Been driving this Tacoma for 3 weeks hoping I will get used to it and maybe it's just because it's a truck... ?? I have low speed vibration on accel. and decel. and sometimes shuddering on deceleration, city driving is really annoying. The problem is less noticeable on incline and shuddering occurs on decline. No problems at higher speeds. This should not exist on a 30K $ truck. You can feel the vibe in park and I noticed it right away when I got the truck. Always had a V6 in my Runners and never had this before, I was sure it was the engine but after driving it for awhile I'm not sure...Hope Toyota finds the problem and does right by it's consumers. I'm putting new Yokohamas in a couple weeks, we'll see if this helps any. I do like the truck a lot despite...
  19. Sep 19, 2009 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only thing I can think of is to make sure they are propperly centered, and propperly torqued.
  20. Sep 19, 2009 at 3:21 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Hmm, I know I torqued them correctly. I put the spacers to just under 100 ft/lbs and the wheels to 85ft/lbs.
    As for centering them I dunno, I can't see how I could screw that up. I put the spacer on tightened them all till they got firm and then torqued them to spec in the star pattern arrangement. Only thing I can think of is I didn't take a wire brush to the contact points. I'm off to buy one right now and redo the front wheels.
    BTW - Blue loctite does taste good! Now to get it off those spacers.
