Where Are You're ScanGauge II Mounted
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrtomphan, Oct 3, 2008.
  1. Oct 3, 2008 at 1:56 AM
    mrtomphan
    mrtomphan [OP] Well-Known Member
    Orange County, CA
    09 Double Cab Long Bed TRD Sport
  2. Oct 3, 2008 at 1:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Oct 3, 2008 at 9:40 AM
    BulletToothTony
    BulletToothTony TTC #0001 Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Mine is in the same place as Janster's, i like it there its easily visible.
  4. Oct 3, 2008 at 10:17 AM
    mrtomphan
    Orange County, CA
    where is the wire run through?
  5. Oct 3, 2008 at 10:20 AM
    BulletToothTony
    I ran mine down the left side of the of the steering column and down to the obd2 port.
  6. Oct 3, 2008 at 10:50 AM
    Janster
    Jandy
    Lancaster, PA
    Same here....
  7. Oct 3, 2008 at 2:32 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    I've never seen one of these Scan Gauges...although, it's on my Christmas list. Once they're connected, do they automatically come on with the ignition, or do you have to switch them on every time?
  8. Oct 3, 2008 at 3:15 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Come on automatically. they're sweet
  9. Oct 3, 2008 at 7:06 PM
    ldm
    ldm Well-Known Member
    Black Diamond, WA.
    08' TRD Off-Road SR5
    ScanGaugeII, Undercover Tonneau
    Same as Janster. I like seeing all the data from the scangauge and truck cluster in the same spot.
  10. Oct 3, 2008 at 7:12 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Mine is mounted to the top of the mirror with velcro.
    Marc M
  11. Oct 3, 2008 at 9:41 PM
    Jester182
    Jester182 Well-Known Member
    SoCal
    08' Taco SR5 Double Cab - Indigo Ink
    Single-din Sony Xplod, SnugTop SL, AFE Pro Dry
    I have mine in the empty slot in the single-din aftermarket dash.
