where can i buy longer u-bolts???
Discussion in 'Suspension' started by wow, Jun 24, 2009.
  1. Jun 24, 2009 at 9:42 AM
    wow
    wow [OP] Member
    falls church virginia
    1998 trd tacoma
    installing aal and one inch spacer in front
    dont want to start and find out u-bolts are too short in back.
    where do you guys buy? online ?
    will stock work? help thank you in advance
    mike
  2. Jun 24, 2009 at 10:09 AM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    not sure if the stock ones will work I just bought longer ones when I got my lift, I got mine from toytec.
  3. Jun 24, 2009 at 10:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Find a local spring (suspension, driveshaft) shop. They should be able to custom make ubolts for you.
    It's hard to order them online unless you know the 'exact' dimensions you need.
    What are you installing in the rear?
    Are you installing an AAL? If yes...then call the manufacturer of the AAL and ask them for some u-bolts if they didn't already come in the kit.
  4. Jun 24, 2009 at 10:56 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    If you have the standard 3-leaf pack and you're just adding an AAL, you can reuse your existing U Bolts. If you have the TSB pack and are adding an AAL, same thing (the dealer should have given you longer ones with the new pack).
    If you're doing a block or an entirely new leaf pack (deaver, dakar, allpro etc) you can get these.
  5. Jun 24, 2009 at 2:25 PM
    Janster
    Jandy
    Lancaster, PA
    Re-using Ubolts isn't necessarily a good thing, especially if you do any offroading. When you re-torque them that 2nd time, they have a greater chance of coming loose. When they come loose, the centering pins can break and all hell breaks loose.
    If you re-use them...just make sure you CHECK THEM to make sure they're staying tight.
  6. Jun 24, 2009 at 2:35 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
  7. Jun 24, 2009 at 3:24 PM
    johnecon2001
    Phoenix, AZ
    You should be checking all the bolts you loosened for the lift anyway. That plus Loctite will prevent any problems.
