Where can I find 108mm to 106mm ALUMINUM hub rings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zach O, Oct 17, 2017.
  1. Oct 17, 2017 at 9:34 AM
    Zach O
    Zach O [OP] Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    So I thought I had fixed my steering wheel vibrations by re-torquing all of my lug nuts but it just started shaking again today (it was good for about 5 days). So the next thing I want to try is hub centric rings but the only ones I can find in this size are plastic and many are saying they break very easily. So do any of you know where to find aluminum ones? Or am I stuck with just trying the plastic ones?
    Thanks in advance.
  2. Oct 17, 2017 at 9:46 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  3. Oct 17, 2017 at 12:21 PM
    Zach O
    Zach
    Texas
  4. Oct 17, 2017 at 2:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There are good reasons for that as 4mm ring that size would be hard to machine and then it will bend easy. Use the plastic ones they will work.
  5. Oct 17, 2017 at 2:57 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  6. Oct 17, 2017 at 3:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I guess I have to take this back as the link above checks out they will make 108 to 106 Custom Aluminum Rings... They are however $25 each...
  7. Oct 17, 2017 at 3:48 PM
    Zach O
    Zach
    Texas
    That's what I figured. I still thought they would be stronger than plastic. I already ordered some of the plastic ones though. :thumbsup:
  8. Oct 17, 2017 at 3:52 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    How strong do they have to be? They just center the wheel before its torqued down. The plastic might be a better option. It's less likely to permenantly deform thus losing its concentricity.
    TacoFergie likes this.
  9. Oct 17, 2017 at 3:53 PM
    Zach O
    Zach
    Texas
    Screw that I just bought 2 sets of four of the plastic ones for $50.
    Jimmyh[QUOTED] likes this.
  10. Oct 17, 2017 at 3:55 PM
    Zach O
    Zach
    Texas
    There were just a lot of reviews that said they had to be replaced at every tire rotation because they were fragile. Not a big deal, I just prefer not having to keep buying hub rings. Especially if I have to keep messing with figuring out this shake.
  11. Oct 17, 2017 at 4:10 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  12. Oct 17, 2017 at 4:18 PM
    Zach O
    Zach
    Texas
    :rofl:
  13. Jun 30, 2021 at 2:33 AM
    Acesolo1!
    Acesolo1! Well-Known Member
    benjamin
    2020 tacoma dbl cab 4x4 v6 sr
    n/a
    So how did the hubrings work out for you?did the shake stop??I'm about order aftermarket rims...one is 106.1mm hub bore and one is 108.mm. Id rather have the 108mm hub bore rim but I dont want issues so I may go with thr 106.1mm hub bored rim....
  14. Jun 30, 2021 at 6:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Removed the wheel vibrations on mine. Plastic.
