Where can I find a diagram/instructions for inspecting cat convertor
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, May 7, 2012.
  1. May 7, 2012 at 11:51 AM
    prerunnerSD
    prerunnerSD [OP] "I Brake for Tailgaters"
    Northeast USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Have a 01 tacoma and its throwing p0420 check engine codes. I am looking for detailed images, diagrams or instructions on where to find the cat convertor and how to inspect the seals before considering buying a new 02 sensor or cat convertor.
    Any advice on where there is a good diagram for this.. I have located the cat and i know it has heat shields to protect it.
    Can take images if you guys are super curious.
    thanks
  2. May 7, 2012 at 5:05 PM
    webb323
    webb323 Well-Known Member
    Jordan
    Tennessee
    97 4x4 Regular Cab (sold), 2014 Double Cab TRD Sport
    It should be bolted on, best way to know for sure if its bad is to take it off... Hold it up to light and see if there is any blockage and try and hear if anything is rattling around inside. If everything looks and sounds goods just get new gaskets and put it back on.. you can also take your oxygen sensors out you should have 4 wires. 2 are for the heater circuit and 2 are for the signal circuit. Put 12 volts DC to the heater circuit then take a propane torch and heat the oxygen sensor and hook and oscilloscope to the signal circuit and check the sin wave. You can google images of what the wave should look like. And you should be able to find the wiring diagram on here somewhere, sorry im not sure exactly where
  3. May 7, 2012 at 5:13 PM
    IGO4LOW
    IGO4LOW Well-Known Member
    Zach
    Fullerton, CA
    2011 DCLB TRD SPORT 4x4 w/ JBL Audio
    3" Procomp lift, 285/70 R17 Nitto Terra Grapplers on Procomp series 6005 wheels, Fog lights on Anytime mod, illuminated oem fog switch, bed mat, all weather floormats, CB Radio in dash, alternating turn signal mod, automatic center console light. Blacked out badges, D2s in the grille.
    :boom:
  4. May 7, 2012 at 5:25 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    I have been a tech for about fifteen years with a breif 3.5 years as welder in the army.With my time as a tech I have never seen anything but replacing the cat be the fix for the p0420 code. The diagnostic flow chart for both toyota and cadillac (the lines I worked for) state check for exhaust leaks if none found replace converter.The exhaust leaks that would cuase this code would be between the air fuel sensor oand the post cat o2 sensor and this leak would be a large leak.
  5. May 7, 2012 at 6:02 PM
    webb323
    Jordan
    Tennessee
    Yeah I should have mentioned in my previous post, on one of my tacomas I had this code and it was the cat
  6. May 7, 2012 at 6:14 PM
    Fast_Freddy
    Fast_Freddy Well-Known Member
    99 Black PreRunner
    ome suspension lift, Borla catback exhaust, S-runner bucket seats
    O2 sensor range is between 0-1 volt and I believe the heater circuit operates with 5 volts, so connecting 12 volts is not a good thing. That being said, you do need an oscilloscope to properly diagnose an O2 sensor...the only proper way to test a cat is with a gas analyzer, the machine used for smog tests. The way to test it is to take a reading pre-cat and post-cat, post-cat results should be reduced by, at least, 60% from pre-cat(or something close to 60%)
  7. May 7, 2012 at 6:23 PM
    webb323
    Jordan
    Tennessee
    Ive tested many oxygen sensors with 12 volts and its worked just fine, and yeah the cat has to be hooked up to smog stuff for 100% but we dont do smog here and most of the time when cats are bad the insides are busted up and you can tell
  8. May 8, 2012 at 5:48 PM
    prerunnerSD
    Northeast USA
    Thanks, with all this good info being said where can I buy a compatible O2 sensor and cat convertor.. Prefer online to support the Tacoma community and to get a good dead..
    Paid Firestone $100 to do a "computer diagnostic" they claimed to have tested the 02 sensor and said the best course of action is to replace sensors and cat for a total of $2500.
    I'd prefer a more affordable option.
    Also tech said that there are 2 sensors on my truck and they both need to be replaced. Is that true? And for that matter isn't there 2 cats????
  9. May 8, 2012 at 5:52 PM
    webb323
    Jordan
    Tennessee
    Yes there are two sensors, no it should not cost that much to get done. By the sensors at advanced then go to an exhaust shop if you dont want to do it yourself. They will mark the Cat price up, but it wont be $2500
  10. May 8, 2012 at 7:30 PM
    prerunnerSD
    Northeast USA
    is it true that there are two portions of the cat convert. that need to be replaced?? or is it just the single unit towards the front??/
  11. May 10, 2012 at 1:51 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    I believe p0420 is the Pre Cat sensor. P0421 is POST cat
    your truck also has 2 usually the second one is the one that goes bad.
    get a Partnumber from the dealers and go to TOYOTApartszone.com
  12. May 10, 2012 at 4:58 PM
    webb323
    Jordan
    Tennessee
    Just a single unit.
  13. May 11, 2012 at 2:11 PM
    prerunnerSD
    Northeast USA
    does anyone know what the part numbers should be that i should order? i am having trouble understanding exactly what and where i should order stuff since there seems two be 2 cats and 2 sensors in all that could possibly be bad.
    the good news is i found a shop in my town that said they'd replace the o2 sensor and cat for $250 max if i provide the parts.. not to bad i say.
  14. May 14, 2012 at 10:49 AM
    Bmangdog
    Bmangdog Active Member
    Brady
    Rogue River
    2000 Tacoma Ex Cab 3.4L 5 Spd
    Cant you rod the cat out of it and just run it empty?
  15. May 15, 2012 at 10:14 AM
    prerunnerSD
    Northeast USA
    Of course you could do that.. i considered that myself but I think i'd need my own private island or country because most places have some sort of emission standards and having no cat would certainly raise some eyebrows lol
