Where can I find a receiver door control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldy54, Feb 19, 2018.
  1. May 7, 2019 at 2:24 PM
    dknappert
    dknappert Well-Known Member
    david
    I'm having the same issue, except where your truck locks and unlocks twice to tell you it's not working, mine won't do anything. I even tried to reprogram my old fob that used to work.
  2. Jan 5, 2020 at 10:32 AM
    Calfrope
    Calfrope New Member
    2011 Tacoma
    Same here exactly. It does nothing at the end of programming when it should cycle locks on/off. I'm considering replacing the receiver control module if I can find it. Any guidance would be much appreciated.
  3. Jan 5, 2020 at 12:05 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Had the same problems as both my remotes became flaky on the lock function and often did not work at all. New batteries no help. On advise of another member I bought a used OEM remote on eBay for $14 and did the reprogram and at the last step the door locks cycled twice meaning it did not take so did all again and same thing but I just said screw it and opened the door to exit programming and guess what - damn remote was actually programmed so all works correctly now. Not the receiver I also suspected. Go figure.
  4. Jan 5, 2020 at 12:17 PM
    Calfrope
    Calfrope New Member
    2011 Tacoma
    Thanks for your response. I found the "receiver door control" and just removed and inspected it. The thing looks brand new inside & out; no burned contacts or any visible issues. FYI after some googling, I learned that Toyota wants between $500 & 600 for a new controller! WTF?!? I couldn't find a used one on eBay or anywhere else. I have no idea how I might bench-test the controller, but I did test the door lock relay and fuse('s) and they're good. So, based on your experience I will order another used OEM remote and try the programming again. This is some crazy mysterious BS. I'll report back on how it goes. Thanks again.
  5. Jun 23, 2023 at 11:24 AM
    Noercarr
    Noercarr Active Member
    PNW
    13 Access 2.7 5MT
    How'd this install go for you? Looking to do the same along with the CC, back up camera and wipers like you.
  6. Jul 17, 2023 at 1:37 PM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    MINE does the same thing... did you ever figure out WHY?
  7. Jun 22, 2024 at 3:36 PM
    tlavergne
    tlavergne Member
    Thomas
    2010 TRD Tacoma
    In reference to old post #9 and #10. I was cleaning out my glove box (2010 Tacoma) and I find this little black box part #89747-AC010. Previous owner must have thrown it in there and I never noticed it. Searched the part# until I hit post #9 and #10. Looked where post #10 said to look and sure enough there was a taped off plug. It fit right onto that part and now I have a beep when I lock or unlock my doors. Have always wondered how to "program" that beep. Now I know.
