where can i find some skid plates?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaSE, Jan 6, 2014.
  1. Jan 7, 2014 at 5:29 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I would imagine so. If you can run a stock skid with a TG bumper then you can run a RAT skid as well.
  2. Jan 7, 2014 at 5:29 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    if your skids use the stock mounting points, they will. i have a the TG low profile bumper and the OEM skid mounts up perfectly.
  3. Jan 7, 2014 at 5:47 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I believe this is the case, but hopefully taco47001 chimes in with some extra knowledge... Does the stock skid work on an elite bumper?
    My IFS didn't directly bolt up to an elite front bumper but with a few modifications taco47001 made it work.
  4. Jan 7, 2014 at 5:57 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks guys! I plan on getting a TG bumper.....eventually.....sometime in my lifetime ...........
  5. Jan 8, 2014 at 5:58 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    I was able to get them to work with a few modifications with my elite. I had to cut 1/2"-3/4" off the front lip for them to fit between the bumper and crossmember. I also had to make a diagonal cut on the side support bends to cut the top rear corners off so it would clear the LCA alignment cams. I can take some pics and post if anyone's interested.
  6. Jan 8, 2014 at 7:05 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    OP, if you can find someone near you that has aftermarket skids then I would make my own based off their dimensions. Luckily I was able to get some Bud Built skids used, but for how simple they are, I would have preferred to just made my own. Even the Bud Builts need additional reinforcing, but depending how hard you are offroad depends on how strong of skids you need.
