Where can i find these ball joint spacers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Huckshot, Apr 11, 2018.
  1. Apr 11, 2018 at 7:11 PM
    #41
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Anything will make ride softer then what you got now.
    Running Board Man likes this.
  2. Apr 11, 2018 at 7:11 PM
    #42
    Huckshot
    Huckshot [OP] Well-Known Member
    Jared
    2000 tacoma 3.4v6 auto 4x4
    3" coil lift spacer in front. 2" block spacers in rear. 6lug to 5 lug adapters. 20" tundra rims with 33" mt tires
    My wife used to have a lilttle beat around 4runner we did a cheapo 3" hockey puck body lift on. Im not trying to jack mine up sky high (at most 6") soo for 50$ in pucks and longer bolts i may just go with that. It worked like a charm on hers with a little fabbing on the bumpers. I have 2" in the rear and about 3" in the front when i bring the front back down so with a body lift added it would be just right..i guess
  3. Apr 11, 2018 at 7:13 PM
    #43
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Block give you more axel wrap which is bad, only good for bro lifts when u wanna put them low pro 35” on 20” rims. Dakar packs or any good after market leaf pack will be either same ride comfert are softer with added lift and travel
  4. Apr 11, 2018 at 7:15 PM
    #44
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Body lifts arnt the good either, going more then 1” on a body lift isn’t recommend, and you gotta change alot more then just the body bushings when u go up more then a 1”
  5. Apr 11, 2018 at 7:16 PM
    #45
    Huckshot
    Jared
    Btw i appreciate all your advice and i can rest easier knowing i have a game plan that wont break the bank and will put some ease on my suspension. I will do a little woods riding but this truck will probably never be a rock crawler...well maybe when i drop a 4bt cummins under the hood when the 5z blows one day :smokertransformer::dancingbacon::bikewhoops:
  6. Apr 11, 2018 at 7:20 PM
    #46
    Huckshot
    Jared
    When we put the 3" on her 4 runner we had to make some bumper brackets and extend the steering rod by loosening the slip joint on it..had to make a 4x4 extension handle and a longer upper rad hose. In the end we spent about 80$ total lifting it and it went everywhere
  7. Apr 11, 2018 at 7:21 PM
    #47
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Cummings r2.8 turbo would be a better engine imo, its lighter then the 4bt
  8. Apr 11, 2018 at 7:25 PM
    #48
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I mean if you want a body lift, then at least do it right and get it from 4crawler...
  9. Apr 11, 2018 at 7:26 PM
    #49
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Your truck must ride like a horse carriage with that ride height. You really need to lower your lift. Remove the spacer for starters.
  10. Apr 11, 2018 at 7:28 PM
    #50
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I'd say ditch the spacer and spend $160 on OME coils. there's your 2.5" up front.
    also from what I gather the original picture was NOT the lift you had, just a reference picture? or did the original owner have that monster spacer and you switched to a red 2" spacer?
    If you plan to lift the front more than 2.5" (suspension) you WILL need new UCAs in order to bring the front alignment within reason as the angles will be way too far off with the stock ones.
    and yes, ditch the Tundra wheels and spacer kit for appropriate Tacoma/4Runner/FJ wheels. You will still most likely need spacers if you run wider than 265 (10.5")
    as others have said, save money now, drop it back down (you will need to get rid of the Tundra wheels regardless) and then plan out. Raising the body does not give you much increased range of motion on trails. Your limiting factor is still the frame and suspension.
  11. Apr 11, 2018 at 7:31 PM
    #51
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    That original photo was from a 2 year old thread from a guy who got a truck that had a drop bracket lift
  12. Apr 11, 2018 at 7:38 PM
    #52
    Huckshot
    Jared
    Doesnt offend me.im just here to learn. Idont plan to take every cheapest way on lifts but i know what works in many cases and in some i dont (which is why im here).im thinking a body lift is really the way to go for what im wanting out of a lift.
  13. Apr 11, 2018 at 7:38 PM
    #53
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Probably the top if his shock is taking the pounding when he bottoms out on bumps
  14. Apr 11, 2018 at 7:42 PM
    #54
    Huckshot
    Jared
    So..im going to just drop the billy back down as far as it will go. Put in the 1" diff drop kit. Get rid of the tundra rims and adapter and get the real deal 6 lug rims.then put a body lift on and wash my hands and have a beer...:proposetoast:
  15. Apr 11, 2018 at 7:43 PM
    #55
    Huckshot
    Jared
    But wouldnt just dropping the setting on the billys do the same as the spacer?i think each notch is like an 1.5" which is what the front spacer is
  16. Apr 11, 2018 at 7:50 PM
    #56
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If i was you i would:
    1 remove spacer lift
    2 put billys to middle setting
    3 buy ucas
    4 get 6lug rims
    5 get diff drop
    6 run a decent tire
    7 get ride of rear block
    8 get dakars
    9 be happy
    10 save up for real lift
  17. Apr 11, 2018 at 7:52 PM
    #57
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    See folks? This is why we don't cobble together a bunch of random parts for lifting your truck. You end up with a bunch of mismatched pieces and HORRIBLE CV angles.
    IMO, if you want something to last, will not ride like crap, and you might actually be able to take it off road someday (even a gravel road), take all those spacers off, ditch the idea of a ball joint spacer (those are freakin scary, imo) and start over.
    Get yourself some Bilstein 5100's, crank those babies up and get an add-a-leaf for the back, and get a diff drop kit (for gods sake, they're $30!!). This will run you about $450 if you do the work yourself (free tool rentals). This is probably the cheapest decent lift you can do. If you want to get all new springs, OME has a kit that's about $1200 for everything except the diff drop kit (I had to modify my skid plate to get it to fit with the diff drop).
    ANy higher and you need a bracket style lift, or need to start doing some serious modification.
  18. Apr 11, 2018 at 7:54 PM
    #58
    Huckshot
    Jared
    What do the aftermarket ucas do other than being trimmed back more?do they drop down to the spindle on any aftermarket ones?
  19. Apr 11, 2018 at 7:56 PM
    #59
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Or trim your bumper, flare your fender, beat the wheel well back and you can run bigger tires with no lift if you wanna be cheap about it
  20. Apr 11, 2018 at 7:57 PM
    #60
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    After market ucas correct your suspension geometry so your ball joint isnt pulled back like yours and you uca isn’t sitting on your coil
