Where could I get a bumper like this?
Discussion in 'Armor' started by themanbearpig012, Feb 18, 2017.
  1. Feb 18, 2017 at 9:07 AM
    themanbearpig012
    themanbearpig012 [OP] Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    Wanting to get some info on aftermarket bumpers. Looking for something close to, if not this same bumper. My questions are.. Where would one buy something like this? Is is prefabricated and bolted on? Custom? Either way looking for websites or fabrication recommendations to make something like this happen. Thank you
  2. Feb 18, 2017 at 9:37 AM
    Pigpen
    Dan
    Northwest Montana
  3. Feb 18, 2017 at 12:44 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2016 TRD OR 4x4 DCSB
  4. Feb 18, 2017 at 1:09 PM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
  5. Feb 18, 2017 at 1:51 PM
    wdavis18
    wdavis18 Active Member
    2014 Black TRD Sport Tacoma (4.0L v6)
    4inch suspension lift, 2inch blocks, 33x12.5xR20 mud tires, front steel bumper
    unnamed.jpg get a Fab fours vengeance series front bumper. (pictured here) they are so sick and super strong!! They also allow for integrated 2 sets of 2 pair rigid industries pods (I installed them a few weeks ago) and a 20inch light bar. I installed the front bumper with my friend in about 5 hours. Once you strip the front stuff, the front bumper is durably bolted on to your chassis
