Where did you all run your wires
Discussion in 'Audio & Video' started by 06SR5canada, Sep 17, 2011.
  1. Sep 17, 2011 at 11:25 AM
    06SR5canada
    06SR5canada [OP] Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Getting ready to run some cable and was wondering how you guys did it before I tear it apart. i plan on using welding cable and copper ring terminals.
    I want one amp under a front seat and one amp one the back wall mounted vertically (saz-1500d)
    any specific spots on the fire wall to go through?
    did you run under your center console or under trim beside door?
    should i make 2 runs to the battery or use a distro block, and where should it be located/mounted
    Where did you ground your amps?
  2. Sep 19, 2011 at 9:44 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    there is a pre fabbed hole in the firewall with a big rubber plug on both sides of the truck...
    that said, i ran it thru with all the other wires and down under the door sill and had it pop under the seat with all the other seat wires...
    grounded the under seat amp to the seat bolts.
  3. Sep 19, 2011 at 9:47 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Power through the giant rubber firewall grommet on drivers side. I recommend poking through from cab to engine, instead of the other way, since there aren't as many wires to hit with your poker in the engine bay once you poke through.
    I've routed wires under both the door trim and the center console. Just depends on where they're from and where they're going.
