Where did you get your speedometer recalibrations done?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Red_Taco33, May 20, 2015.
  1. May 20, 2015 at 10:39 AM
    Red_Taco33
    Red_Taco33 [OP] Well-Known Member
    Upstate New York
    2021 TRD Off-Road MT
    It's been a while since i put on my 35's, and my speedometer is 5 mph off. I called Toyota and they said they couldn't recalibrate it. Im guessing everyone went to shops to have it adjusted, i was just wondering where you got it done.
  2. May 20, 2015 at 10:41 AM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I too am curious so I am going to piggyback on this thread...
    :wave:
  3. May 20, 2015 at 10:41 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I was under the impression most people don't
  4. May 20, 2015 at 12:02 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
  5. May 20, 2015 at 12:06 PM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    My speedo is way off, can a Scanguage or Ultraguage be adjusted to give the right reading? I know they show speed, not sure if they can be adjusted though
  6. May 20, 2015 at 12:08 PM
    DVexile
    Ken
    Yes, they can be adjusted. So if you want to use your scangauge/ultragauge as your speedometer that is one way to do it.
    ranger098[QUOTED] likes this.
  7. May 20, 2015 at 12:08 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Does anyone on here have any experience with the recalibration voiding a warranty? For example if you brought in a truck with a bad transmission with 59K on it with an aftermarket recalibration that if stock would be covered by the 60K powertrain?
    I know I have had a bunch of friends buy old 4 runners with 35's and they don't care about the incorrect mileage but would it effect resale on a dealer trade in for example?
  8. May 20, 2015 at 12:08 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Just use a GPS, and put speed marker stickers on the speedometer gauge.
  9. May 20, 2015 at 12:23 PM
    ATLien
    ATLien Well-Known Member
    Portland
    2013 DCSB SR5
    Money Pit
    Mr Grimm has some in-line device he used on his build thread
  10. May 20, 2015 at 7:57 PM
    Red_Taco33
    Upstate New York
    Ehhhh i could live without adjusting it but after a while i'd rather just get it fixed
  11. May 20, 2015 at 8:44 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  12. May 20, 2015 at 8:47 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    well its a redneck solution but you can always open up the cluster and push the needle forward a few mph :wink:
  13. May 21, 2015 at 12:07 AM
    Earle
    Earle Well-Known Member
    Earle
    Huntville, AL
    11 double cab
    Not with my Tacoma, but with my little Miata "play car," where I replaced my OEM 17" tires/rims (ridiculous for that car) with 15", I plan to have my wife help me re-mark the speedometer, using the GPS...
  14. May 21, 2015 at 8:51 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Change to the proper gear ratio, maybe. :notsure:
  15. May 28, 2015 at 4:12 PM
    Earle
    Earle
    Huntville, AL
    11 double cab
    Not really worth the trouble at all...
    braik likes this.
  16. May 28, 2015 at 5:57 PM
    Pigpen
    Dan
    Northwest Montana
    I'm only on 33s, but I used the GPS and have a pretty good "guesstimate" how fast I am going. If I really need to know (don't know why I would) I can just use my torque app - mph calibrated to tire size.
  17. May 28, 2015 at 8:22 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  18. May 29, 2015 at 7:58 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I've actually installed the Hypertech In-Line speedometer calibrator. It works great.
    It gets tiresome after a while not to have your speedometer and odometer reading accurately. My speedo went from reading too slow when I was on stock gearing on 33" tires - to reading too fast when I regeared to 4.88.
    1. Open the box.
    2. Plug it into your PC with the cable.
    3. Run the software and enter your tire size and gearing.
    4. Remove your dash cluster (this is the hard part - but it's not too bad)
    5. Plug in the calibrator. There's a right way and a wrong way - so BE CAREFUL!
    6. Reassemble everything
    7. Drink adult beverage
    http://www.hypertech-inc.com/products-speedometer-calibrator.aspx
    Biscuits likes this.
  19. May 29, 2015 at 8:17 AM
    07tacoswb
    07tacoswb Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    I have the hypertech calibrator. It works great. I have had 35's with 4.56 gears and had no problem getting it right. Now I have 33's with the 4.56's and just a little adjustment and everything is great. I have had mine for several years.
  20. Jul 16, 2015 at 5:02 PM
    sddarkman619
    sddarkman619 Well-Known Member
    Larry
    San Diego
    2015 Tacoma Sport TRD
    None(Yet)
    I called Hypertech and asked if they have one for a 2015 and they don't, yet. I wonder if the 2014 model will work on my 2015 taco? Anyone, Bueller?
