Where did you guys hide your capacitor
Discussion in 'Audio & Video' started by taco06, Apr 5, 2010.
  1. Apr 5, 2010 at 8:01 PM
    taco06
    taco06 [OP] Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Where did you guys hide your capacitor? I have an access cab.. I put an amp under each seat... WOndering where can I add the capacitor?
  2. Apr 5, 2010 at 8:08 PM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Don't bother. If your charging system is ok and you properly wired everything you don't need one.
  3. Apr 5, 2010 at 8:11 PM
    taco06
    Alex
    pomona ,California
    06 sprt
    My system is 1000w.... I had this same system in an another car with a capacitor...I just dont know where I can add it and be hidden... In the engine bay?
  4. Apr 5, 2010 at 8:17 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    I'd upgrade the battery before adding a cap aka bandaid
  5. Apr 5, 2010 at 8:27 PM
    86ceeten
    Brian
    NW Florida
  6. Apr 5, 2010 at 9:54 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I know you're feeling regretful that you wasted your money on a capacitor. However, that's no reason to put yourself through the hardship of mounting that terrible device. The stock alternator (even without the larger alt with the towing package) is quite capable of throwing down 1000rms. That's not a huge amount.
  7. Apr 5, 2010 at 10:04 PM
    taco06
    Alex
    pomona ,California
    06 sprt
    any one want a capacitor?
  8. Apr 5, 2010 at 10:30 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    i rock one with my setup up. My lights dimmed with the power i have. I have two Kicker 750.1 and one 350.4. If i dont count the 4ch, i have 1500rms with it just on. But you should mount it within 18" or less from your amps. Thats the safest way. Plus the stock alts cant really handle the load draw for to long with what i was told from another member here which is about 13XXwatts. To much load for to long will shorten the life or your alt.
  9. Apr 5, 2010 at 11:06 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    Just get a better battery! I'm running 2600 watts rms off a Kinetik 2400.
  10. Apr 6, 2010 at 3:48 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    the cap does help. well i got mine for free so i don't care what anyone thinks lol...i have mine under my seat.
  11. Apr 6, 2010 at 3:59 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    batteries dont provide more power for the continuos amp draw. alternator is you option to pump out the required juice. srry OP i dont have advice on the capicitor.
  12. Apr 6, 2010 at 4:24 AM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    2016 4Runner 4x4 Limited Metallic Gray
    5K LED interior lighting
    Ok, I have a few points though it is a bit of a tangent to the thread. (Sorry to the OP that I don't really know a good location to mount the Cap.. though I'd think right under the amp horizontally would work as long as you have the clearance to not short out on the back wall...)
    A note on amplifiers:
    An amp may say it is "1000 Watts." 99% of the amplifiers out there state their PEAK rated power versus continuous output power. You may even have something sick like a 2400 Watt amp, but I'd be willing to bet that on an amp like that, unless you paid $2000+ for it, its peak power is something WELL short of that.. most likely only about 25% of that. If you are using a high-end amplifier that either underrates their output or is very true to their word, 1000 Watts is not only a lot of juice, you better have some hellacious speakers to munch the power, or you will blow those suckers right out of their baffles. (FYI, 1000W continuous at ~14V = 71.4A) If you are really bumpin, you will suck your battery dry faster than you can charge it.
    On charging systems:
    Like others have said, I DO strongly recommend a stronger battery designed for the drain, like an Optima Yellowtop battery. But a battery only gets you so far. If you do have high current subs, a capacitor or a bank of caps is certainly the way to take the hit off your battery. If you are running multiple high current amps, you will really need a bigger alternator... a place like http://www.ohiogen.com/ can custom wind them to your specs. (I have one in an '84 Firebird that is a rolling stereo.... it has a 230A alternator.. and I have 4 x 1 Farad caps in front of an Xtant X1000 and an Xtant X604 --- that is 1600 Watts RMS (and underrated.. prob more like 2200+ W)) I will tell you that even with the 230A alternator, and an optima yellow top with garden hose for wiring your headlights will still dim a little with no caps when you are bumpin. A Tacoma has WAY WAY more electrical systems draining on the alternator than '84 Firebird... my car doesn't even have fuel injection... haha
  13. Apr 6, 2010 at 4:50 AM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    ^^^^ very true about rated continous watts vs rms vs max rated... but i believe you divide the wattage ie 1000w by 12 volt power source instead of 14 like you stated. correct me if i am wrong
  14. Apr 6, 2010 at 4:55 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Under one of the access seats?
  15. Apr 6, 2010 at 5:00 AM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    Try this:
    Go put a multimeter on your battery with your engine off... it will read about 12-12.5 volts.. (maybe 13 if it is FULLY FULLY charged).
    Now, crank the motor. With the motor running, touch the battery terminals with the multimeter again. It will more than likely read between 12.8 -13.5 depending on the motor idle speed (if it is cold/hot, etc.) Now have a friend run the engine speed up to about 2k-3k RPM (please do this safely) and repeat the reading. The voltage should be 13.5-14.5 ish. When you are truckin down the highway, the alternator has a slightly higher output that would be closer to 14.5. I took 14 as a rough average while motor is running.
    EDIT:
    FYI, this is the first basic test for a bad alternator.. if the voltage does not drastically increase when running vs being off, your alternator may not be charging correctly.
  16. Apr 6, 2010 at 5:55 AM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    I am not a capacitor fan, but since your question isn't about if you should buy one or if they work, I will try to answer your actually question.
    If I were to have a capacitor, I'd mount it near where my power wire is running. If it is on the driver side, then I'd put it under the driver's seat or maybe under the center console under the storage compartment.
  17. Apr 6, 2010 at 6:54 AM
    ItalynStylion
    Steven
    DFW, Tx.
    I was under this impression as well.
    Which is why I'm so confused as to why the outlet in the bed is good for 400watts of power when the truck is idling and stationary but while moving it's only 100. Seems ass backwards to me. :confused:
  18. Apr 6, 2010 at 6:58 AM
    GT_Taco
    GT_Taco Newbie here
    Marietta, GA
    It is backwards.. but it is the limitations A) of the inverter, and B) I guess Toyota's design didnt want you running anything 'substantial' back there while in motion...
  19. Apr 6, 2010 at 7:58 AM
    ItalynStylion
    Steven
    DFW, Tx.
    My guess was B.
  20. Apr 6, 2010 at 11:03 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I have a 02 so mine is under the rear seat cubby, driverside:
