Where did you mount your CB transceiver?
Discussion in 'Audio & Video' started by MadeInMaine, Sep 2, 2010.
  1. Sep 2, 2010 at 12:50 AM
    MadeInMaine
    MadeInMaine [OP] MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Hey Guys
    Can you post pictures of where you mounted your CB Transceivers?
    I can't seem to make up my mind on where to mount mine.
    Thanks
    Cheers
  2. Sep 2, 2010 at 9:19 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    Here's mine. It doesn't ever really get in the way. Even when entering and exiting the truck. Plus, it's close to the firewall which makes coax installation a breeze for a hood mount antenna.
  3. Sep 2, 2010 at 2:24 PM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    nice fellas...
    any more?
  4. Sep 20, 2010 at 6:40 AM
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    2014 Subaru STI hatchback
    Tuned by Snail Performance, 305WHP/350TQ on E85, Corsa Pro Series black tip CBE, Perrin CAI, Perrin ELH, Invidia catless DP, ID1000 injectors, Turbosmart Dual Port BOV, Turbosmart IWG Actuator, Cobb FPR, Perrin motor and tranny mounts, Moroso dual catch cans, Cobb AP V3, Grimmspeed turbo heatshield, Grimmspeed EBCS, Perrin pitchstop mount, Kartboy bushings, battery tiedown, oil cap, Perrin reverse lockout leaver, Hella Supertones horns, GT-Spec flat bottom steering wheel, Rally Armor mudflaps, Pioneer 4600BT HU, JL Audio door speakers, sub, and amp, Weathertech floormats, Grimmspeed LWCP, Perrin front license plate delete and relocator, Perrin alternator and radiator shrouds, Grimmspeed master cylinder brace, TWM Gunmetal M1 Abrams shift knob, Defi boost and oil pressure gauges, SMY Clustermaker dual gaugepod, JDM black side badges, Greddy magnetic oil drain plug
    you probably already mounted it, but here ya go :D
  5. Sep 20, 2010 at 6:49 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    I just mounted mine yesterday... and that is exactly where I mounted mine.
    now I am just having trouble getting it up and going.
    Got antenna setup, cable run, CB powered, CB mounted, but its not working...
    trouble shooting time!
  6. Sep 20, 2010 at 6:56 AM
    Special_K
    Special_K o_o
    Eddie
    Alameda, CA
    Well I hope you don't run into the same issues I did....my original set up was a midland CB with Matt's (RecklessTaco) old 4ft antenna. Tri let me borrow his SWR meter but I kept getting really high readings. I couldn't figure out where my problem was, finally gave up and had John at Audio Plus take a look. He ran a voltmeter through my system and it turn out the radio I got from Fry's was a dud!!! I was so pissed but now I've got a Uniden with a 4ft firestick and it worked great on the trails this past weekend.
  7. Sep 20, 2010 at 7:03 AM
    MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Not sure what the problem is. It CB powers up, but the channel indicator flashes "y", and no signal lights show up...
    Not really sure what's going on
