Where did you route your Ipod cable?
Discussion in 'Audio & Video' started by zphly, Jun 13, 2012.
  1. Jun 13, 2012 at 9:44 AM
    zphly
    zphly [OP] Active Member
    DC
    '12 TX Pro
    I'll be getting a new aftermarket head unit shortly and I'm a little on the fence as to where I'd like to route the Ipod/accessory cable (i.e. to the center console, glove box, loose change cubby by the steering wheel... etc. :notsure:). Just wondering where you all have yours routed and if you have any advice. Pictures would be appreciated!
  2. Jun 13, 2012 at 9:47 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Mine just flops out in the open. I try to keep it looped around the gearshift though.
  3. Jun 13, 2012 at 9:49 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Mine is in the glove box. Mainly so I don't sit there and look at it trying to change songs. Also, I leave my phone in their plugged in to my USB ports. Just run the blue tooth and avoid getting into wrecks or tickets for texting/driving!
  4. Jun 13, 2012 at 9:50 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Up through the center console. I have a 6 speed. FYI. It's all the same , out of sight and pretty easy to get to.
    AZ
  5. Jun 13, 2012 at 9:54 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Glove box, have the "trucks" ipod plugged in and left in the glove box all the time.
  6. Jun 13, 2012 at 9:57 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    This is what I need to do, I have an extra Ipod. I like having my calls and GPS from my phone come through the radio though. The GPS just interrupts the music when it needs to tell me to turn.
  7. Jun 13, 2012 at 9:58 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    glove box, and i control it through the headunit. I also have a regular headphone jack in the change holder to the right of the steering wheel for if i want to play from my laptop or a friend's non-ipod MP3.
  8. Jun 13, 2012 at 10:05 AM
    Haslefre
    Brady
    TN
    2019 Tundra
    I actually have an additional hard drive in my glove box I run music/movies off of. The unit I got has 2 USB ports, and IPod port, and a headphone jack. I love being able to run as much stuff as I can... just wish it was more powerful of head unit.
  9. Jun 13, 2012 at 11:08 AM
    Cheehoo
    Cheehoo Um, I don't have a "member"
    Angela
    Southern Utah
    A hard drive as in, actual USB detachable hard drive? I didn't even think of trying that, good idea. My USB plug doesn't register my android phone as an mp3 device, it tries to open the files that I have on it, but won't play music.
  10. Jun 13, 2012 at 11:09 AM
    Haslefre
    Brady
    TN
    2019 Tundra
    Yes, actual USB detachable hard drive. 500gb hard drive that sits in the glove box with movies and music. Takes a bit to load up sometimes, but it works like a champ when started.
  11. Jun 13, 2012 at 11:38 AM
    resq330
    resq330 El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    Hmm...my aftermarket Kenwood wouldn't recognize my usb hard drive. Just my jump drive.
  12. Jun 13, 2012 at 11:40 AM
    Haslefre
    Brady
    TN
    2019 Tundra
    Maybe not enough juice to spin the drive? May need to find a solid state (no spin) HD for it?
  13. Jun 13, 2012 at 12:15 PM
    resq330
    Josh
    VA
    Good thought. Thanks.
  14. Jun 13, 2012 at 1:12 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    It would probably load faster too.
  15. Jun 14, 2012 at 6:34 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ...or a shorter USB cable, sometimes a disk just needs a bit more power then a long cable can supply
  16. Jun 14, 2012 at 6:43 AM
    Haslefre
    Brady
    TN
    2019 Tundra
    According to the USB cabling, you can have up to a 5m long cable before it gets too slow. 3m is the prefered amount for USB 2.0. Now, USB 3.0 can actually only be 3m long as well, but it operates upwards of 5gb/s. I just wish I could upgrade my HU to run USB3.0 instead of the 2.0... but I might have to find a better way to power up the HU.
  17. Jun 14, 2012 at 7:21 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not talking about cable length as it relates to data signals, but rather that the 5V 0.5A power line in the USB cable will lose amps as it gets longer. Shortening the cable keeps the amp loss down. I had this happen on an older Pioneer HU with a 3.5" 20GB disk. Disk would not spin up with 6' cable, but dropping down to a 2' allowed the disk to spin up.
  18. Jun 14, 2012 at 7:40 AM
    Haslefre
    Brady
    TN
    2019 Tundra
    I need to pull the HU back out to see what kind of cables mine are. I think mine are hardwired in though, which will be my problem to change them. But, they are only 4ft at the max? I really wish I could upgrade the whole thing to USB3.0, but that would take too much work.
  19. Jun 14, 2012 at 7:47 AM
    bjasper
    bjasper Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    I love to show mine off, I drilled a hole above the dash scoope and ran the wire throught there. It's really easy to grab and go or change iPods.
  20. Jun 14, 2012 at 8:00 AM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    Mine is in the compartment right next to the shifter. Its perfect to hold my iphone
