Where do I check for transmission fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vivica89, Oct 26, 2009.
  1. Oct 26, 2009 at 8:44 PM
    vivica89
    vivica89 [OP] Well-Known Member
    Los Angeles, CA
    '06 TRD PreRunner Double Cab
    Hi, I have a '06 double cab TRD PreRunner and I don't know where to check the transmission fluid. Is it the power steering wheel fluid? There's no dip stick for this model right?
    Thanks,
    Vivica
  2. Oct 26, 2009 at 8:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw!
    the transmission is a sealed transmission...so there is no dipstick. the dealer will need to check it for you...and its a certain process they go thru to check them on the 2nd gen. tacomas.:)
  3. Oct 26, 2009 at 8:51 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Welcome!
  4. Oct 26, 2009 at 9:07 PM
    vivica89
    Los Angeles, CA
    Thank you Tacomaman06. Will the warning light show if the fluid is low? How often should it be checked?
  5. Oct 26, 2009 at 9:09 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
  6. Oct 26, 2009 at 9:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Tacomaman06 is correct. Have a dealer check it. Not sure if there is a warning light or not.
  7. Oct 26, 2009 at 9:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no problem. yeah, if its low....a warning light should come on...........but if the truck is under warranty, you may wanna get them to check it now if you suspect anything wrong or anything. but for the most part...you should be fine.....and with now hauling/towing......100k miles is what toyota recommends on the change interval.:)
  8. Oct 26, 2009 at 9:35 PM
    vivica89
    Los Angeles, CA
    Question.. I took my truck to the dealer last Thursday cause the maintenance req'd light went on. I recently had my oil change last month. After the complimentary inspection, they told me I needed to get my valve cover replaced and that my truck has oil leak. I checked my oil today and it was fine. They said it will cost around $600-$700. Does it cost this much to get it replaced?
  9. Oct 26, 2009 at 9:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im thinking your valve cover is probably fine. Many times, oil can spill from the bottle when filling, leading the dealer to tell you its the valve cover. To fix the miantinance light, with the engine Off, and the key in the ignition, press and hold the ODO Reset button. While holding it pressed, turn the key to the ON position, and wait for the ODO to reset to 0. Then, the maint light is reset. :)
  10. Oct 26, 2009 at 9:54 PM
    vivica89
    Los Angeles, CA
    Thanks Chris.. Just to be safe, should I take the truck to a different dealer? And do you know how much it would normally cost?
  11. Oct 26, 2009 at 9:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....I would have another dealer look at it. You can also take some close up pics of where the valve covers meet the engine, and post them on here. There are alot of folks on here that I would trust over a dealer. :) As for cost....Im not sure. I havent ever heard of one needing a replacement not covered under warranty.
    miller29 likes this.
  12. Oct 26, 2009 at 10:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Sounds like they're trying to sell you a mound of bullshit.
    Open up your hood and take a look for yourself. Do some research and learn about valve covers & all that auto stuff. Never believe what a dealer tells you unless you research it yourself. 2nd oppinions are also a good idea if you're in doubt....
  13. Oct 26, 2009 at 10:19 PM
    vivica89
    Los Angeles, CA
    Thank you all for your help!
  14. Oct 27, 2009 at 8:16 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    The maintenance req'd light comes on every 5000 miles regardless. The truck could be in perfect condition, it's gonna come on every 5000 miles to remind you to do your oil change.
  15. Oct 27, 2009 at 8:35 AM
    vivica89
    Los Angeles, CA
    Thanks Asgard. Good to know.. How often should I check the transmission fluid? Every time I get an oil change or sooner?
  16. Oct 27, 2009 at 8:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It really shouldnt need checking unless there is a leak. Its good for 100K miles before scheadualled maintinance.
  17. Oct 27, 2009 at 8:50 AM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Welcome to TW!
  18. Oct 27, 2009 at 9:50 AM
    vivica89
    Los Angeles, CA
    Thanks Agent475.
  19. Mar 13, 2018 at 12:33 AM
    miller29
    miller29 Member
    wesley
    pa
    black sport
    just some chrome detailing
  20. Mar 13, 2018 at 12:43 AM
    miller29
    miller29 Member
    wesley
    pa
    black sport
    Yes that is the key word "Warranty". The dealerships do a good job when the truck is under warranty. But i know when my 05 Tacoma ran out it need about 600.00 dollars worth if work. I took to my mechanic it was about $50.00 part and $30.00 labor charge lol. But if it wasnt for an oil chang you could weld the hood shut and never have to worry about anything with these TOYOTA'S lol. My Tacoma is 13 years old and I plan on handing it down to my 7 year old so he cand it down to his kids lol. It will be just getting broke in.
