Where do I go to get my bearing pressed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Garbageman, Jun 6, 2022.
  1. Jun 6, 2022 at 12:15 PM
    Garbageman
    Garbageman [OP] New Member
    95 taco 4x4 manual
    Hey everyone! Long time reader first time poster.
    Last week my wheel bearing went bad, rumbling the last mile or so home. I jacked it up and it had probably a half inch of play vertically.
    I have been calling shops and junk yards in the seattle area for the last week, trying to either find someone who’s willing to press the bearing out and press a new one in, or find a full knuckle assembly to swap over.
    I figured someone on these forums would have been through this process before, maybe even in the same area, and could lend some advice. Please and thank you.
  2. Jun 6, 2022 at 12:20 PM
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    Look for an automotive machine shop. Some Napa stores also do work like this.
  3. Jun 6, 2022 at 12:25 PM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Sounds like a good excuse to buy a press from harbor freight
    Area51Runner likes this.
  4. Jun 6, 2022 at 12:26 PM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
  5. Jun 6, 2022 at 12:28 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Can second zippsub, great guy
  6. Jun 6, 2022 at 12:54 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Yup- That's the type of shop you're looking for. Most of the time local shops will send their press work out. If you ask nicely, the shops should be able to point you in the right direction.
    You may also want to post in the regional forums to get some more localized suggestions or even other members with a press willing to help you.
    Consider doing both wheel bearings- the other one probably isn't far behind.
  7. Jun 6, 2022 at 1:58 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Find a Shop that has done Toyota Front Wheel bearings before. So easy to screw up.
    Post in your local forum quite a few from that area.
    leid likes this.
