Where do I mount ARB Compressor??
Discussion in '4 Cylinder' started by musicmaan, May 20, 2012.
  1. May 20, 2012 at 8:15 PM
    musicmaan
    musicmaan [OP] Member
    Where the sun don't shine...... Literally
    not enough
    Just wondering where other people are mounting their air compressors with the 2.7L?? Where I have seen them mounted on other Tacomas, I have the 4WD controller and the cruise control in the way. Honestly, I have no options under the hood that I can see.... so, what are my other options??
    Thanx
  2. Dec 30, 2012 at 12:44 PM
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
    +1
    Installing mine right now, not sure where to put it though
  3. Dec 31, 2012 at 10:09 AM
    musicmaan
    not enough
    I fingered it out.... Remove the air intake silencer box that sits above the fender. Plug the hole with something of substance, and hose clamp it so it stays put. Once this step is complete, proceed to drill holes in your trucks metal parts, and mount said pump!
  4. Dec 31, 2012 at 10:10 AM
    musicmaan
    not enough
    It's still a tight fit, but it's the only place that is available under the hood
  5. Jan 2, 2013 at 4:24 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Here is the ARB twin under my '03 2.7 pre-runner...
  6. Apr 2, 2015 at 6:27 PM
    dirtymike420
    dirtymike420 Well-Known Member
    TEXAS
    TuRD off oad
    anyone mount them in the bed with a topper on it?
    PNdub_Taco likes this.
  7. Apr 13, 2015 at 7:46 PM
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I hope to install one soon. I have a Leer DCC aluminum cap. I plan to mount the compressor to the left bedside in front of the wheel well.
  8. Apr 13, 2015 at 7:56 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    I bolted my Airlift compressor on the fender behind the battery for airbags, and ran the wiring back to the cubby box on the drivers side. Which fuse would be good to use for a +12v keyed?
  9. Apr 16, 2015 at 3:43 AM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Bueller. Anyone?
  10. Apr 16, 2015 at 4:02 AM
    Large
    Large Red
    Add a fuse from the cig lighter ckt to a relay, run the compressor off the relay
  11. Apr 17, 2015 at 1:31 AM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    I'll take a look for it and research installing a relay. I'm decent with wrenches, but not so much electrical. Was hoping to tap into a fuse. Thanks.
  12. May 4, 2015 at 7:00 PM
    dirtymike420
    TEXAS
    TuRD off oad
    Mine is still sitting in the box.... Can't make the call on which way to go.
  13. May 12, 2015 at 4:16 PM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
  14. May 12, 2015 at 7:23 PM
    Ritchie
    I have seen them and others mounted under the hood more often than not.
    I have had no issues with mine,
