Where do i route wires for radio thru firewall ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by togah, May 21, 2010.
  1. May 21, 2010 at 7:55 PM
    togah
    togah [OP] Active Member
    garry
    corpus christi tx
    2007 tacoma prerunner
    need help.....cant find any grommeted holes thru the firewall to run a radio lead wire....coax out thru where?/ any suggestions....am i missing something i do not see any ....also any help on mounting a 1/4 wave ant to top would be nice grounding?? thanks guys !!!!:):confused:
  2. May 21, 2010 at 9:05 PM
    A7XT
    A7XT Reppin UWYO
    Kyle
    WYOMING
    '09 TRD Sport V6 Silver
    BRUTEFORCE FAB HYBRID BUMPER!, 1.5 AAL, 5100 at 2.5" in front, foglight and DRL mod, fully de-badged, diff-breather mod, aux backup lights, rear view switch on mod, full husky floor liners, yellow wire mod, black action packer toolbox, Rockford P3SD412 sub on a hifonics Zues, Pioneer 4200DVD, hitch recovery shackle, Toyota Ski racks over bed, 55W Bixenon 6000K, Rigid 4" LED bars on bumper, Black Ultra Thunder 17" rims
    As far as running stuff through the firewall, there is a huge rubber grommet in the drivers side engine bay that you can poke a small hole in or run it through the edge of the grommet. You can see this grommet from the engine bay or behind the pedals. Hope this helps
  3. May 21, 2010 at 9:45 PM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    I've ran two 8 gauge wires through the hole for the hood release wire. It's above the grommet for the wire harness on the drivers side. It was a tight fit, but a stiff wire and some wire lube got the job done.
