where do I send wires into cab?
Discussion in 'Lighting' started by 09tacorunner, Feb 20, 2013.
  1. Feb 20, 2013 at 12:00 PM
    09tacorunner
    09tacorunner [OP] Well-Known Member
    Duke City
    09 PreRunner TRD OffRoad
    HELP! I'm wiring up my rigid industries LED Dully lights. I have them mounted to a BAMF behind the grille light bar. all I need help with is how or where to slide the wiring into the cab of my truck. I know that there is that hole near the parking break that has a rubber holder but I cant get it out and I dont want to damage anything of the wiring with in that rubber holder. I can slip the wiring around the outside of that rubber piece but then I would run the risk of cutting or tearing the wire harness im trying add.
    ANY HELP WOULD BE APPRECIATED!!!
  2. Feb 20, 2013 at 12:12 PM
    09tacorunner
    Duke City
  3. Feb 20, 2013 at 12:14 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    use an awl and poke a little hole in that rubber boot... will work fine. that is the easiest way to pass wires through the firewall.
  4. Feb 20, 2013 at 12:15 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    13 minute bump?
    Run it through where the rest of the wires go in on the drivers side of the engine bay through the rubber boot. Sent my power cable for my amp through there.
  5. Feb 21, 2013 at 6:57 AM
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    +1
    All my wires run through there. Amp, Antenna Cable, Warning light wires
    Use a wire hanger or fish tape to help pull wires htrough
