Where do the plug wires go?
Discussion in '1st Gen. Tacomas (1995-2004)' started by todntes, Sep 5, 2009.
  1. Sep 5, 2009 at 7:26 AM
    todntes
    todntes [OP] Member
    Todd
    Seattle
    00 Tacoma SR5
    Am i missing something?
    I have a 2000 Tacoma with the 2.7l 4cyl engine and I cant figure out how to change the plug wires or where the coil packs are. I bought a set of wires that were to match but the wires in the truck are not typical wires. The wires coming from the plugs are small and run into a wire duct on the firewall. I am getting a misfire trouble code, that is the reason for wanting to replace the wires.
  2. Sep 5, 2009 at 2:33 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The coilpacks are located in front passengerside of engine almost below the radiator hose on top. Are you sure about trouble code ? If so, look for a split some where in the ducting that the wires dissappear into so you can separate it. But before you do anything make careful note of the wires & there location,which wire to which cylinder so on (kinda of a no-brainer there) Maybe get with the tech forum here and download some manual pages to your year & type. Good Luck:cool:
  3. Jan 9, 2011 at 1:38 PM
    rufuss1959
    rufuss1959 New Member
    can anyone help me change the spark plug wires on my 2001 4 cydr prerunner? the plug wires on the old wires are made up of several small wires. the are going into a bundle that is taped together. do i need to remove the wrap to remove the old plug wires? any help would be greatly appreciated.
    thanks
  4. Jan 10, 2011 at 4:15 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2002 Tacoma 4x4 TRD 2.7
    The 2001 Tacoma with the 2.7 only has ignition coils attached to the boot covering each spark plug, so there isn't any wires for you to replace. Hope this helps.
