Where do you ground stuff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 20somethingwidataco, May 16, 2019.
  1. May 16, 2019 at 4:04 PM
    20somethingwidataco
    20somethingwidataco [OP] Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Any good areas to ground things? My negative terminal and battery ground are getting full with my lights, sound system, horns and halos. I need to organize it a bit. Thanks!
    Biscuits and whatstcp like this.
  2. May 16, 2019 at 4:07 PM
    eon_blue
    Azusa, CA
  3. May 16, 2019 at 5:07 PM
    20somethingwidataco
    Will
    Washington State
    That's a little more than i want to spend for just a few grounding points Haha. My wires are organized. I just want more ground options
  4. May 16, 2019 at 5:17 PM
    Danny72
    Danny72 Well-Known Member
    Wilmington, NC Area
    2011 DCSB 4x4 TRD Taco
    35x12.5r18s RC 6" Lift w/resies, Camburg UCAs, 3rd Gen Leafs, Brute Force Fab Front Bumper, HC Coastal Offroad Rear Bumper w/Swing-Out
    Totally thought you were talking about Jiu Jitsu and I got excited :(
    Biscuits, Alexely999 and ChemDawg like this.
  5. May 16, 2019 at 5:32 PM
    ToolPac
    ToolPac Well-Known Member
    Show Low, AZ
    2018 TRD Pro, 1998 TRD
    You could get a simple ground bus. I'm curious how you're powering all that stuff though. Do you have an auxiliary fuse box?
  6. May 16, 2019 at 6:25 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    My auxiliary fuse block has a ground for every circuit. I got tired of having wires running every which way.
  7. May 16, 2019 at 6:30 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    This + That and you'd be well organized
    ONLINE LED STORE Waterproof Relay/Fuse Block for Automotive and Marine [6-Slot Bosch Style Relay Holder] [6-Slot Blade Fuse Holder] [Silicone Seals] Fuse Box for Jeep Boat Car Or Truck https://www.amazon.com/dp/B07MR64XK1/ref=cm_sw_r_cp_apa_i_q6G3CbQCRSCA9
    Geraldo's Taco and Biscuits like this.
  8. May 16, 2019 at 6:30 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It’s not good to ground directly to the battery. Any bolt that is ground will suffice, however is using sensitive equipment just be cautious of ground loops that can induct noise
  9. May 16, 2019 at 7:33 PM
    20somethingwidataco
    Will
    Washington State
    Who what now
  10. May 16, 2019 at 7:34 PM
    20somethingwidataco
    Will
    Washington State
    Nope, just lots of rings on my positive terminal lol
  11. May 16, 2019 at 7:34 PM
    20somethingwidataco
    Will
    Washington State
    whatstcp[QUOTED] likes this.
  12. May 16, 2019 at 7:35 PM
    20somethingwidataco
    Will
    Washington State
    I like that! It would help clean up a lot. All existing relays plug into it?
  13. May 16, 2019 at 7:38 PM
    slowboater
    slowboater Well-Known Member
    Why?
    I thought it was the opposite.
    I’m about to run a cable from my battery to the bed for power. I have cable to run to the ground of the battery and was going to set up a bus to ground everything (lights and usb chargers).
    But I did always hear that a ground is a ground is a ground....
  14. May 16, 2019 at 7:41 PM
    m603holden
    Marteeen
    New England
    Include wires to waterproof and plug into the relays
  15. May 16, 2019 at 7:45 PM
    ToolPac
    Show Low, AZ
    You should definitely get one. Someone posted a really good one in here that doesn't even need a ground bus. It's all in one box clean and safe.
  16. May 16, 2019 at 9:55 PM
    20somethingwidataco
    Will
    Washington State
    Boom! Ordered. Going to mount it close to my battery ground. Should help clean up a bunch thanks!
  17. May 17, 2019 at 12:18 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It’s best to keep your ground point as short as possible. It kind of doesn’t make a whole lot of sense with electrical theory, but run a high powered amplifier directly to the battery, vs a short solid chassis ground and you will see just how much more strain it puts on the system. Will grounding directly to the battery still work? Yes. But it’s not the best way to do it.
    Larzzzz likes this.
  18. May 17, 2019 at 11:31 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Go to the home cheapo electrical department. Near the panels and circuit breakers should be ground bars. It's skinny with lots of screws in various lengths and it has an L bracket for mounting. Mount that, and transfer everything from the battery the large holes in the ground bar will take a #3. Run that to the battery negative or bolt it with the battery ground in the truck.
  19. May 17, 2019 at 11:44 AM
    20somethingwidataco
    Will
    Washington State
    Yup, I just ordered one from Ebay. Currently have 4 grounds to the battery negative and 3 to the battery ground. Should help clean things up a bit
  20. May 17, 2019 at 11:47 AM
    slowboater
    Yep, that's my plan.
