Where do you ground stuff?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 20somethingwidataco, May 16, 2019.
  1. May 17, 2019 at 12:31 PM
    gnardoggie
    gnardoggie Well-Known Member
  2. May 17, 2019 at 3:09 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    As @Lawfarin said, it is best to keep the grounds as short as practicable. The wire has resistance, that eats up voltage before it gets too what it's being used for. Running both wires doubles that resistance. Make sure the connection at the body/ frame etc. Is clean metal and you should be good to go. Up size the battery grounds as well and your golden. :thumbsup:
    Lawfarin likes this.
  3. May 11, 2022 at 7:01 PM
    denuir
    denuir Member
  4. May 12, 2022 at 4:12 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    1 gauge copper (110 amp rating at 140F) if planning on drawing 100 amps through the bus bar. Realistically, add up the amps of what will be flowing through the bus bar and select the right gayge accordingly.
    https://www.aic-controls.com/wire-size
    denuir likes this.
  5. May 12, 2022 at 7:02 PM
    denuir
    denuir Member
    Much appreciated @Chuy
