Where does this hose go?
Discussion in 'Technical Chat' started by Davtopgun, Mar 4, 2013.
  1. Mar 4, 2013 at 4:04 PM
    Davtopgun
    Davtopgun [OP] Weeeee mod time!
    David
    Central Alabama
    2014 TRD Off-Road
    TacoAlaMode Custom grill, SCS Gunmetal F5's, Treadwright guard dogs, King extended travel coilovers w/800# springs, OME Dakars. LRUCA's. Allpro off-road plate rear bumper with high clearance hitch, steel breaded extended brake lines front and rear, SOS concepts bolt on rock sliders with top plate, Pelfreybuilt front plate bumper, rci skid plates, Airflow Snorkel, Tom Woods custom one piece drivesahft, Weathertech in channel rain guards, Bushwacker fender flares, custom cab height bedrack, 60" Hi-Lift jack w/Mount, Recon 10,500lb waterproof winch with synthetic line, rear bumper light pods, front bumper light pods and light bar.
    I popped my hood a little while ago and found this hose loose. If you have a 3.4l, could you tell me where this hose goes? It appears to be going into the intake tube, though I cannot see any connection for it. My truck has a K&N cai setup (It was there when I bought the truck).
    The engine is hesitating when I hit the gas, and I'm mot sure if this hose has anything to do with it.
    BTW, I just put in a new fuel filter. The old one was in pretty terrible condition. I don't see how a new fuel filter would cause any problems, but it's a good idea to post up that I just changed it.
  2. Mar 4, 2013 at 4:07 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    maybe a vaccum line or to the tb?
  3. Mar 4, 2013 at 4:14 PM
    Davtopgun
    David
    Central Alabama
    2014 TRD Off-Road
    It's not a vacuum line, has no suction. I think it may fit a stock intake, and I just never noticed it loose before.
    The hesitation in the gas pedal seems to have stopped. I just wasn't patient enough after changing the filter. I assume it had to work the air out of the line.
    Would still like to know where that hose goes though. If I can get someone to go look under their hood. Would be much appreciated.
  4. Mar 4, 2013 at 4:32 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    i can tomorrow, its dark and effin cold right now
  5. Mar 4, 2013 at 4:36 PM
    Davtopgun
    David
    Central Alabama
    2014 TRD Off-Road
    ^^^ Thanks, and Bump if someone has theirs in their garage and wouldn't mind checking it for me?
  6. Mar 4, 2013 at 4:52 PM
    Supertramp
    Supertramp dismember
    NC Mountains
    2002 Access cab TRD
    3 inch lift, Fox coilovers
    Mine goes around the back of the intake and connects here, hope this helps.
  7. Mar 4, 2013 at 4:55 PM
    Davtopgun
    David
    Central Alabama
    2014 TRD Off-Road
    I'm trying to see the same perspective that you took the picture from. If that's the firewall on the right, then it's the other end of the hose that i'm after. Thanks for the info!
  8. Mar 4, 2013 at 5:15 PM
    Supertramp
    NC Mountains
    2002 Access cab TRD
    Different angles.
  9. Mar 4, 2013 at 5:40 PM
    Davtopgun
    David
    Central Alabama
    2014 TRD Off-Road
    SuperTramp, I really appreciate the photos. It appears that your hose setup is different then mine. I guess the setup changes between my 95.5 3.4l and your 02 3.4l. I have a third larger hose running with the other two over top of the intake. Like the first pic I posted.
    Thanks for your help!
  10. Mar 4, 2013 at 5:44 PM
    Supertramp
    NC Mountains
    2002 Access cab TRD
    Sorry it different work out, maybe someone with an earlier 3.4 will chime in.
  11. Mar 4, 2013 at 5:46 PM
    Davtopgun
    David
    Central Alabama
    2014 TRD Off-Road
    Hopefully, Thanks again!
  12. Mar 4, 2013 at 8:12 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Dave, is that your 95.5? Wow you got that engine cleaned up nice. I see you took out the modified intake system and installed a stock one. I have Phillip's 99 at the shop. I will look and see if I can tell where that hose goes.
  13. Mar 5, 2013 at 3:52 AM
    Davtopgun
    David
    Central Alabama
    2014 TRD Off-Road
    No, it's not mine. That's a photo I found on google. I wish mine was that clean. Still on the market for a stock air box, too. Thanks
  14. Mar 5, 2013 at 7:25 AM
    BamaToy1997
    Bill
    Navarre, FL
    Dave, I just looked at Phil's 1999, and his goes from the metal line to a port on the plastic/rubber intake pipe from the air cleaner box. I am thinking from what I remember seeing, that you don't have that. The best I can suggest is to find a way to extend it and pipe it into the intake pipe at some point. That hose would draw un-metered air into the engine, and could definitely cause you issues, as it is not measured by the mass-airflow sensor. Any way you can take a fresh pic of your under hood? I can't remember exactly how it is set up.
  15. Mar 5, 2013 at 7:38 AM
    Davtopgun
    David
    Central Alabama
    2014 TRD Off-Road
    I'll get a pic when I get home. Currently working on getting a stock air box.
