Where does your clutch start to engage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BobinMN, May 13, 2024.
  1. May 13, 2024 at 7:00 AM
    BobinMN
    BobinMN [OP] New Member
    Bob
    2020 TRD Sport
    I replaced my clutch, flywheel and throw out bearing this weekend with a kit from Centerforce. First off, for me, this was a huge job to do in a garage with jack stands on a creeper and cardboard. Took about 7 hrs to get everything off and another 7 to get it all back. Spent about $130 for a transmission jack and 6 feet worth of socket extensions.
    My oem clutch would start to grab around the top 2 inches of travel. The new clutch grabs around the bottom 2 inches. I don't know anyone with another manual Tacoma to compare it to so I'm wondering what others are getting for pedal travel before the clutch engages.
    I bleed the line once when I put it in. I may bleed it again and see if that makes a change.
    This could be completely normal, I just have no comparison. I also have less than 30 miles on the new one so there may be some change some more drive time.
  2. May 13, 2024 at 9:19 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    Mi e is still oem and it grabs in the last two inches of the peddle. I'm assuming you setup is still hydraulic?
  3. May 13, 2024 at 9:44 AM
    BobinMN
    Bob
    2020 TRD Sport
    Yes, hydraulic clutch. After thinking about it some more, I think I will start there and bleed it again. I only did about 8 pumps of the clutch to bleed it when I did it after the replacement.
  4. May 13, 2024 at 9:53 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  5. May 13, 2024 at 9:55 AM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Mine grabs pretty early, towards the bottom of the stroke wen letting off of the clutch
  6. May 13, 2024 at 9:55 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    Yeah my oem clutch grabs at the very top
    Tacosha and Junkhead like this.
  7. May 13, 2024 at 10:09 AM
    BobinMN
    Bob
    2020 TRD Sport
  8. May 13, 2024 at 3:04 PM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    I happen to also have a Centerforce clutch. Mine engages around 2 inches of the bottom I guess?
  9. May 13, 2024 at 3:43 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Same here
  10. May 13, 2024 at 5:58 PM
    danny15l
    danny15l Well-Known Member
    2022 white Tacoma TRD sport MT
    nada
    Dang that’s too bad it’s grabbing differently. I test drove a manual truck about 6 months back that also had a new clutch and it grabbed at the very bottom quick. this was a 2001 F150.
    felt awkward getting back in my Tacoma. either it needs to be bled or the master/slave cylinder is going bad.
  11. May 13, 2024 at 6:05 PM
    BobinMN
    Bob
    2020 TRD Sport
    That's good to hear. At least there is some consistency. The Centerforce feels like it has a lot more grab than the original. The original was getting worn so maybe it just feels new. I also have the heavy flywheel. It must be about 15-20 lbs heavier than the stock. I think about 45 lbs in weight. My real world test is getting up my driveway. I can keep the rpm's down and it just crawls right up. The oem needed a bit of gas and ride the clutch a bit. That flywheel was a real joy getting it lifted in place while on my back and getting a bolt started.
    abou824 and Northerntaco69 like this.
  12. May 14, 2024 at 6:30 AM
    shaggy135
    I somehow burnt my OEM out under 40K miles. Never have I ever burnt a clutch out. (I put 155K on an 05 Corolla and my 15 Jetta has 110K currently. Bought both new and both had no clutch issues.) I went with Centerforce because they got great reviews and they are in AZ. I really didn't see a point in putting OEM back in if it was going to fail so quickly. I also had my mechanic do the accumulator delete. Then I happened to grab a Core shifter too, so mine is a lil different than most, ha. All that plus a weighted shift knob from @7r41lbr34k3r when he was making them.
  13. May 14, 2024 at 6:34 AM
    abou824
    Aidan
    Central PA
    Every time my clutch gets smelly it's from reverse, thanks Toyota for the horrible 3rd gen reverse gearing...
