where is hidden Fuse box location
Discussion in '1st Gen. Tacomas (1995-2004)' started by catdr.93, Jul 17, 2024.
  1. Jul 17, 2024 at 7:29 PM
    catdr.93
    catdr.93 [OP] Member
    Alexis
    Tacoma 2003
    I have a Tacoma 2003 extra cab V6 with factory installed towing wiring. Worked on one trailer with all lights working. Then I hooked up trailer #2 and lights suddenly stopped working. Circuit testing shows power only going to brown wire on 4 way flat connector and Converter. Interior and under the hood fuses are good. There is no black box behind back seat on drivers side. Got under my truck and traced trailer wires. There is a wire bundle goingTacoma wiring 1.jpg into the cab under the drivers seat. Doesn't seem logical. Anyone else have this? Any other location I should look?
  2. Jul 18, 2024 at 5:48 AM
    1blink
    1blink Well-Known Member
    Storm Mtn, CO
    2000 3.4 manual SR5
    Trailer lights often splice in behind the tail lights
  3. Jul 18, 2024 at 9:08 AM
    catdr.93
    Alexis
    Tacoma 2003
    Thank you 1blink. I’ve read that aftermarket wiring does that. I don’t see any wiring going towards lights but I’ll check again
  4. Jul 18, 2024 at 12:35 PM
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    You don't have a little box attached to the back wall of the cab a bit below the rear window? I have the factory trailer wiring and frame mounted receiver under the bumper. I bought it from the Toyota in 2004 and installed it myself with the directions provided. The conversion from 5 wire to 4 wire is handled by that Toyota box that on the single cabs is mounted on the reinforcement crossbar just a little below the top of the seat backs. Perhaps it was located in a different place on extended cab trucks?
  5. Jul 18, 2024 at 2:00 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    :notsure: Pull the door scuff plate (four screws) and peek under the carpet and see what's under there. There is for sure a harness connection there, so maybe whoever installed the trailer kit thought it would be suitable location for the trailer controller.
  6. Jul 19, 2024 at 12:52 PM
    catdr.93
    Alexis
    Tacoma 2003
  7. Jul 20, 2024 at 3:41 PM
    catdr.93
    Alexis
    Tacoma 2003
    To Andy01DblCabTacoma: so I did what you suggested and can see where a lot of wires connect to black housing. I'm now trying to figure out how to physically accesse the area and pull out the unit to examine more. Thank you for your suggestion I feel like I'm getting somewhere.
  8. Jul 20, 2024 at 8:07 PM
    catdr.93
    Alexis
    Tacoma 2003
    I forgot to add the pictures I took
  9. Jul 22, 2024 at 7:28 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    To gain access to those- remove the front seat (four bolts, and one wire connection for the seat belt indicator), remove the kick panel (they just pull straight back), and peel the carpet up.
    That being said, the wires coming in from what you're calling the trailer harness, look factory to me. They are fuel pump, abs, locker (if equipped) and rear light related. Someone has obvious been in there though- I assume the blue wire is power to that under seat sub you had?
  10. Jul 22, 2024 at 11:35 AM
    catdr.93
    Alexis
    Tacoma 2003
    Thank you to all who have helped me. I'm embarrassed to say that I was wrong about trailer harness wire placement. I removed all the tape and zip ties encasing a slew of wires all bundled together. Then, I was able to accurately trace the wires to the rear lights. Also, this system was not factory installed. When purchasing my Tacoma, I was under the impression the wiring was factory installed. However, it was the Hopkins brand harness. Arghh. Now, I'll put the carpet back under front seat and install the Hopkins product.
    My apologies to Blink1 for not following your suggestion. You were right.
    Thanks again to all
  11. Jul 23, 2024 at 7:17 PM
    1blink
    Storm Mtn, CO
    2000 3.4 manual SR5
    sweet! glad to know you solved it
