Where is my vibration coming from?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country101, May 16, 2012.
  1. May 16, 2012 at 7:24 AM
    Country101
    Country101 [OP] Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    I just installed an OME kit on my truck(coilovers, leaf packs, shocks, and carrier bearing drop kit). Install went great. Now I have noticed a shuddering at take off up to 10mph and then a smaller vibration on up to almost 50 that you can barely feel. I've read some on differential vibration, but I am not hearing a growl. I may be hearing something, but I am more than likely making myself hear this or it is not very much at all. How can I tell if it is my driveline or differential? If it is driveline, I need to get axle shims and new centering pins, right? What would I need to do if it is up front? A whole new unit, or did I read somebody had come out with a bushing to fix it?
    I have a dif drop kit that I have not installed as well. I was just told to try the hose clamp boot mod.
  2. May 16, 2012 at 8:23 AM
    ajwhlr04
    ajwhlr04 Well-Known Member
    Aaron
    Woodland Hills, CA
    2007 Tacoma 4x4 Double Cab 6MT
    I'm relatively new to the forum but I've read up on this, anticipating any issues with a lift, but I'm not an expert by any stretch. Most people seem to try putting it in 4HI while in motion. If the vibe goes away, it's probably the front diff. There's a needle bearing that supports the driver side axle - the interface between the two has too much play in it. Check out this thread for front diff vibes (hopefully these links work):
    http://www.tacomaworld.com/forum/2n...nt-differential-bearing-vibration-thread.html
    From what I understand, messing with front *may* cause vibes coming from the front driveline (the front diff). Messing with the rear *may* cause vibes in the rear driveline (transfer case and rearward). here's and interesting thread on shimming the carrier bearing/ rear axle/ etc to get rid of rear driveline issues:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/153050-just-fixed-driveline-vibration-free.html
    EDIT: by 'front' and 'rear', I meant adding a lift to those locations.
  3. May 16, 2012 at 9:54 AM
    Country101
    NW Arkansas
    Thanks aaron. I am thinking it is my driveline. That thread definately has some good info. Hopefully I can figure it out somewhat quickly. It bothers the crap out of me.
  4. May 16, 2012 at 9:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Most vibrations are caused from impropper torqing of the U bolts, and such. You should take the Carrier bearing drop off, and torque the U bolts to 80#, see if that helps.
  5. May 16, 2012 at 10:45 AM
    Country101
    NW Arkansas
    I'll get my buddy to save me his magazines. I dont get them, but I was talking to him about them just the other day, so I know he does.
  6. May 16, 2012 at 12:20 PM
    ajwhlr04
    Aaron
    Woodland Hills, CA
    Rear leaf U bolts? How does the carrier bearing affect those? I think I'm missing something...
  7. May 16, 2012 at 2:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It doesnt. However, most people add these spacers, trying to chase a vibration tha tis simply created from bolts that havent been tightened correctly. Then they end up throwing spacers all over their truck (Diff drop, CB spacers, etc.), when all they had to do was make sure all the bolts/nuts are propperly torqued. In all the lifts I have installed, none had vibes, or needed CB spacers.
  8. May 16, 2012 at 6:23 PM
    josh2002
    josh2002 Active Member
    I had the same problem I had put a 6" on with 33s and had that when I took off it ended up being the carrier bearing I put a new one on it got better then I added ladder bars and it went away
  9. May 16, 2012 at 8:54 PM
    ajwhlr04
    Aaron
    Woodland Hills, CA
    VERY good to know! Thanks!
