Where is oil filter location?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MannyS, Sep 13, 2015.
  1. Sep 14, 2015 at 2:08 PM
    #61
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I get that but I'd rather not risk cracking a plastic filter cap without having another on hand. The drain bolt gasket has been replaced once, the one time it actually came loose and I had to use the filter cap wrench to get the cap off. As for the drain bolt, I doubt it's going to leak since once the bolt is out you have to insert a plastic nipple to drain the cap and that in itself is not easy to snap on. Trust me, I evaluated the risk based on the design and experience with it and it's an acceptable risk to me and I'm sitting at 78k miles without any issues so far.
  2. Sep 14, 2015 at 5:29 PM
    #62
    spp
    spp OC, Kalifornia
    OC California
    That is the correct way to do it. I always beat the time limits and have to change several times a year.
  3. Sep 14, 2015 at 5:52 PM
    #63
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I stick to a 5k interval.
  4. Sep 14, 2015 at 5:53 PM
    #64
    Silverwing
    Silverwing Well-Known Member
    USA
    Land Cruiser- 200 Series- BP-51's- Bud Built sliders- KO2's -
    Looks like an after market company could be born here... Build a well machined filter with smooth spinning parts vs. that plastic toyoda crap with metal inserts... Looks like $100.00 upgrade... I guess a Fumoto valve would hang too low... anyone tried a Fumoto valve on this set up???
  5. Sep 14, 2015 at 5:56 PM
    #65
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    There's no plastic on our 2008 sienna canister.
    Both parts look like cast aluminum to me.
    I wonder about compatability?
  6. Sep 14, 2015 at 6:03 PM
    #66
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    They think they're trying to save the fucking world again. Smh
  7. Sep 14, 2015 at 6:31 PM
    #67
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Whoever did the oil change on it before did it wrong. The drain bolt has a very low torque rating. Like half that of the filter cap.
  8. Sep 14, 2015 at 6:39 PM
    #68
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    You mean the factory? Cause I got it with 15 miles on the ODO and performed the first oil change myself and it's been this way since first oil change.
    Doggman likes this.
  9. Sep 14, 2015 at 6:48 PM
    #69
    thepinktaco
    thepinktaco Well-Known Member
    Cody
    Orange, MA
    95 SAS Tacoma, 99 4runner, 16 Tacoma.
    The only time we get problems with the plastic housings is when someone over tightens the filter, which happens a lot. All you need to do is just snug it up, not reef on it. Same thing happens with the aluminum ones but it's much easier to get the plastic ones off when you have to break them.
    Toyota went with this design back in 04 but just started using it on the truck motors. It's more cost effective for them, increase their profits, and less impact on environment by not throwing out a metal filter every oil change. It's a win, win, win for them
  10. Sep 14, 2015 at 7:54 PM
    #70
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    That's probably smart. I change my current car's oil every 3k right now but manual suggests it.
  11. Sep 14, 2015 at 7:56 PM
    #71
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    Since my first truck (22re) I change the oil every 3K. No matter what the manual says. Particullates don't have a timeline.
    robssol likes this.
  12. Oct 17, 2015 at 7:03 AM
    #72
    mtsrunner
    mtsrunner Well-Known Member
    I'm glad my deal on my truck is coming with free lifetime oil changes. I have always changed the oil on my previous vehicles, but this looks like a pita.
    107main likes this.
  13. Oct 23, 2015 at 7:22 AM
    #73
    107main
    107main Active Member
    Me thinks I like my 14 TRD more and more after some of the things I see on the new 16. This oil filter arrangement is a piece of crap! Why Toyota, would you do that. The level of skill of your oil change folks may make this a challenge to changing the oil. What was wrong with the old method. My trade plans are on hold now.
  14. Feb 12, 2016 at 6:25 PM
    #74
    Tacoma_Jake
    Tacoma_Jake Well-Known Member
    2016 Tacoma TRD OR DCSB
    Not sure anyone noticed but on the new 2017 Tacoma TRD PRO looks like they changed the skid plate design so you dont have to drop the plate at every oil change.
    " 5. There’s a new, oil change-friendly front skid plate.
    Sweers says current TRD Pro owners complained about having to remove the quarter-inch plate to change the oil. Now they don’t have to."
    shakerhood likes this.
  15. May 14, 2016 at 7:26 PM
    #75
    bpp1015
    bpp1015 Member
    2016 White Limited Double Cab Taco
    Factory Stock
    I found a link on this website that referenced a Lexus Aluminium housing (p/n 15620-31060) that replaces the composite housing. Not only does it replace it, you don't have to change out the inner tube assembly. I used copper anti-seize when I reinstalled it on the aluminium threads. Granted I had to put the composite in a vice and then remove the "3/8" drive plug. Reinstalled it in the new housing as per torque specs stated on it. This was all done at the first oil change at 4750. I then drove the truck 450 miles the next day, stopping after the first 80 miles to check for leakage; none. I have the same composite housing on the wife's 2014.5 Camry. I obtained the filter wrench from Ebay for $12.00 listed as a Aluminum Oil Filter Cup Wrench Tool 64.5mm 14 Flute FITS TOYOTA LEXUS USA SHIPS ( 161368846190 ). I made a point to not order the composite one. Works on my Taco and the Cam.
    #75
  16. Jun 28, 2016 at 4:01 PM
    #76
    SunSpot97
    SunSpot97 Member
    Terry
    Maryland
    1992 SR5 V6 & 2016 TRDS
    None
    There is something that I noticed nobody has brought up. When I wrenched for a living we would get the occasional Harley come in with a "Death Rattle". I'd cut the flange off the canister filter with a big pipe wrench and then pull out the paper pleated filter assembly from the can, grab a box cutter and cut the pleats away from the center metal cylinder. You could then spread the pleated paper part of the filter open (about 3" x 15") and shine a trouble light (shop light for some of you) on it. At this point the engine health is pretty obvious....think of "panning for gold". OldyTyme Harleys (70's and earlier) had these canister filters too and you could get a quick look at any differences from one oil change to the next very easily. Trouble is evident in the filter pleats well in advance of engine noises and major problems. So don't just pitch the filter and curse the mess. Take a closer look at it and get to know your engine on another level.
  17. Jan 1, 2017 at 10:19 AM
    #77
    va_trailrunner
    va_trailrunner Member
    I just got my Tacoma, so I haven't changed the oil yet, but the design of the Tacoma oil filter isn't new to me. My 2011 Tundra had the same design. The biggest problem with that truck was dealing with the heavy skid plate on that big truck. I never looked forward to the wrestling match getting that thing back on.
    Every time I changed the oil in my Tundra, I removed the drain plug with a 3/8 drive. The trick I learned from a Tundra forum was to take the plastic drain tool, put it in an empty wine bottle, and shove that up into the filter housing until it snapped in place and the oil started flowing. The oil in the filter assembly would drain in to the wine bottle, and I'd dump that into my drain pan. When I would next unscrew the housing, and there would only be a little bit of oil left in the housing.
    I've always changed my oil every 3k miles with synthetic. I did it at 4k on my Tundra, but I'll probably do it every 5k on my Tacoma, with an extra change at 1k. My friends tell me I'm wasting my money, but my other two Toyotas are 13 and 15 years old, and still running strong.
  18. Jan 1, 2017 at 11:34 AM
    #78
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Floki likes this.
  19. Jan 28, 2017 at 11:55 AM
    #79
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    That's the correct tool.
    xJuice[QUOTED] likes this.
  20. Jan 28, 2017 at 12:12 PM
    #80
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    iversonhof, Floki, EB Group and 2 others like this.
