Where is the 2nd 12v outlet?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pumita, Jul 17, 2020.
  1. Jul 17, 2020 at 12:18 PM
    Pumita
    Pumita [OP] Member
    Pete
    Inferno 2018 Tacoma TRD Sport
    I feel like I'm losing my mind here. In the specs, it says there's 2. Keep in mind I'm notorious for not being able to find simple things.
  2. Jul 17, 2020 at 12:20 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The front wall of the center console.
    :cheers:
    Chew and Junkhead like this.
  3. Jul 17, 2020 at 12:20 PM
    jets
    jets Active Member
    805, CA
    2018 TRD OR DCSB
    inside center console
  4. Jul 17, 2020 at 12:20 PM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    Did you check inside the center console (where you lean your elbow)?
  5. Jul 17, 2020 at 12:30 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    There’s also a cutout for the charging wire to stick out of the center console.
    Chew and tonered like this.
  6. Jul 17, 2020 at 12:32 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    2018 is the last year with 2, right? 2019+ put two USB ports in the center console cubby.
  7. Jul 17, 2020 at 12:34 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Good point. But 99% of the time, someone is going to use the OG power ports for USB power / charging these days. :D
  8. Jul 17, 2020 at 1:08 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yes the 12V outlet is more flexible. USB charging tech advances every couple of years, with Quick Charge 3.0, Power Delivery, etc., so it's better to be able to upgrade the USB charging adapter. The round outlet also lets you clock the adapter in different orientations and keep the wires tidy, esp. with 90-deg USB cables.
    tonered[QUOTED] likes this.
  9. Jul 17, 2020 at 1:12 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very true.
    In the past I had been very dependent on charging. Thankfully, my current phone is over half way through the life that I am expecting and still doesn't need topping up. That is new territory for me.
