where is the A/C amplifier ire is located on the 2014 tacoma ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jsemog, Dec 16, 2016.
  1. May 30, 2024 at 3:29 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    This will tell us what we're missing at the relay, then depending on that we have direction on what to test next, Toyota modules rarely fail so I wana eliminate all other possibilities before going after the module.
  2. May 30, 2024 at 3:50 PM
    cheopr2
    cheopr2 Member
    jose lopez acosta
    2014 blue tacoma trd
    none
    thanks my friend..ill continue tomorrow...i appreciate your help..back tomorrow...thanks
  3. May 31, 2024 at 12:24 PM
    cheopr2
    cheopr2 Member
    jose lopez acosta
    none
    couldnt do nothing today...busy in some others things...mi truck is in my son house...iam planning on bring it to my house and work here ...
    let you know....take care
  4. Jun 13, 2024 at 1:57 PM
    cheopr2
    cheopr2 Member
    jose lopez acosta
    none
    thanks for your help///still iam looking for a 2014 tacoma to test my own ac amplifier...i installed anew compresor today....but still the same flashing light.....another mechanic told me to buy an amplifier....btu the logic is to test mine first..imagine if i buy a new one almost 500 dols,,,and the problem persist???iam stuck with this situation//////
  5. Jun 13, 2024 at 2:39 PM
    cheopr2
    cheopr2 Member
    jose lopez acosta
    none
    do you have a suggestion? or anyone reading this?
  6. Jun 13, 2024 at 3:13 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you ever do the tests I outlined?
  7. Jun 13, 2024 at 4:15 PM
    cheopr2
    cheopr2 Member
    jose lopez acosta
    none
    today another mechanic installed another compressor...after that ..flashing light appears againg...no ground from amplifier...he made some tests and determine a that my ac amplifier had to be tested...in another truck...i wish i could find a test to bypass the different sensors that active the ground in the amplifier for the magn relay.....do you know...?.after i get it fix..i am going to get rid of this Taco...too many headaches.....
  8. Jun 13, 2024 at 4:35 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I gave you the tests to do, not sure why we replaced the compressor when we were pretty confident it wasn't that?
    I just helped someone else through the same issue using the same test I was trying to have you do on an 07 and we found the MG CLT Relay control wire was broken between the A/C Amplifier and the MG CLT Relay.
    https://www.tacomaworld.com/threads/2007-tacoma-a-c-blinking-light.834279/#post-29890418
