Where is the AC evaporation drain located?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Jul 31, 2012.
  1. Aug 1, 2012 at 1:59 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    yea rubber is not exactly my forte :thumbsup:
    here ya go.. not sure how the tube stays into the "port".. you can move it around a lil, its not fixed into place
  2. Aug 1, 2012 at 2:02 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    Thanks man. I can only imagine how much Toyota would charge for that part.
    And it seems like with the way mine currently is, it would be prone for a bunch of crap to get into it.
    I may have to "take a look under my friend's '02 hood" while he's not looking. :D
  3. Aug 1, 2012 at 3:44 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    just get a brass tube from HD or Lowes and put a nice curve in it. Ram that up in there and put a worm clamp on it.
  4. Aug 1, 2012 at 3:53 PM
    Madjik_Man
    So I went to Toyota, just to see what the price was for that part.
    Turns out you can't get it. Never could.
    He also explained to me that some trucks came with it and some didn't.
    If the AC was installed at the factory, you got that 90 degree aluminum piece. If the AC was installed at the dealership as an option, you didn't.
    Learn somethin' new every day
  5. Aug 1, 2012 at 7:23 PM
    TIPICOTACO
    Tyler
    nw nj
    ^ interesting. I was wondering if it was a year to year thing or what?..
    do what hossmaster said, should be a piece of cake
  6. Aug 30, 2014 at 7:22 AM
    grillmaster
    grillmaster Active Member
    Texas
    2014 DCSB SR5 TSS Sport
    I like the idea of a brass tube as opposed to plastic tubing due to heat displacement from the engine and exhaust.
    My issue is, I am unable to locate this A/C drain line from under the car. I did see a black 1.5 inch rubber hose sticking horizontally through the firewall.
    If somebody could take a picture and place a pointer or finger pointing to where I would insert the brass tube with a worm clamp, it would be much appreciated.
    Thank you one an all for these exceptional mod write-ups.
  7. Aug 30, 2014 at 7:53 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  8. Mar 19, 2019 at 3:53 PM
    Melvin 01 Tacoma guy
    Melvin 01 Tacoma guy New Member
    2001 Toyota Tacoma
    I'm still confused as to where this a/c evaporation drain line is located, my passenger floorboard was sopping wet the other day. I have aan 01 Tacoma Prerunner. Any pictures would help tremendously, thanks
  9. Apr 12, 2019 at 2:30 PM
    2001 Toyota Tacoma
    I blew air up in my drain line and tried a coat hanger wire also and mine still doesn't drain, but if I use my AC my floorboard will be wet, any suggestions now? Thanks ( 01 Tacoma Prerunner.
  10. Jul 2, 2019 at 9:23 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I'm a bit late but... It sounds like you need to disassemble the whole assembly. If you haven't fixed it pm me.
    04Pre_Runner likes this.
  11. Aug 21, 2020 at 11:21 AM
    Broken Tine
    Broken Tine New Member
    Great thread - showed me what to look for.
    I had the same issue on my 2003. Turns out a dirt dauber had blocked the hole with dirt (truck sat for a while). The coat hanger trick did the job. There must have been about 10 ounces of water that poured out once the hole was unobstructed. Thanks for the help!
  12. Aug 21, 2020 at 12:03 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Mine is the opposite. It looks like something is leaking. It drains out so much. Lol.
    I checked and it’s just the norm
  13. Aug 21, 2020 at 12:42 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  14. Aug 17, 2021 at 1:57 PM
    sultan_of_sludge
    sultan_of_sludge Well-Known Member
    ZK
    2001 Tacoma TRD
    Just replaced my *entire* AC system and the thing would literally drip for 10-12 hours straight after running for a cruise around town.
    I HAVE the metal barb (factory AC option hell yea :cool:)
    Pulled the barb out of the rubber doo-dad and out came a SH*T LOAD of water.
    For me, the clog was in the metal barb itself.
    Blew out a heap of trash from the metal piece, and we are golden. I'll be adding a section of hose to relocate any drops away from my frame / sway bar.
    Thanks, Crew.
    -Z
