where is the ac relay on my 01 tacoma
Discussion in 'New Members' started by radioflyer55, Jul 1, 2013.
  1. Jul 1, 2013 at 10:52 AM
    radioflyer55
    radioflyer55 [OP] Member
    Dave
    Walterville, Oregon
    03 Dbl.Cab SR5 4X4
    3"revtek lift, 1"throttle body spacer, airaide cold air intake system,dual exhaust w/flowmaster mufflers
    I have a 01 tacoma 4x4 xtra cab and the ac will come on and go off intermittently and i can't find the relay anywhere. It's not in the fuse block under the hood, the only thing in there is a fuse which is fine, and there isn't a relay marked with MG/CTL either. "So where is it?" Any help would be great!
  2. Jul 1, 2013 at 10:55 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    There is another fuse panel under the dash also. May be something there.
  3. Jul 1, 2013 at 11:09 AM
    radioflyer55
    Dave
    Walterville, Oregon
    03 Dbl.Cab SR5 4X4
    TACO TX
    Yes, I have already looked there for a fuse but no luck.
  4. Jul 2, 2013 at 8:38 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I don't think the A/C has its own separate relay. There is a relay for the blower (called the heater relay). The A/C has its own computer for controlling everything.
    You could have low 'freon'. A sensor detects low freon, and could cause the computer to shut off the compressor.
    There is also a heat sensor (thermister) in the evaporator. If it detects that its about to freeze, then the computer will shut off the compressor.
  5. Jul 2, 2013 at 9:46 AM
    radioflyer55
    Dave
    Walterville, Oregon
    03 Dbl.Cab SR5 4X4
    TAN 4X4
    Yes, I think you are right because last night I stopped by Wally World and bought one of those DIY freon loading kits which has a can of R134 and a hose with a gauge on it, And I hooked up the hose to thee low side and looked at the gauge and it only read 20 lbs. So I loaded the freon until I had about 40 lbs.in it and took it out for a test run, Turned on the ac and presto it worked. Needless to say my wife was very happy because the temps here in the northwest have been very hot for this time of year. Now I can get" My" truck back from her and we both can stay cool. Thanks for the tips guys I really appreciate it.
    Dave
