where is the best place for amp in access cab
Discussion in 'Audio & Video' started by DBK4, Aug 15, 2009.
  1. Aug 15, 2009 at 1:59 PM
    DBK4
    DBK4 [OP] Member
    California
    05 PreRunner TRD Off Road LIFTED
    3inch. lift, with bilstien shocks, XD series rims, K&N air filter system
    where is the best place for an amp to go in an access cab. i am trying to put a sub in and need a place to put the amp but cant find a big enough spot for it. the amp is a kenwood KAC 7204 and the demensions are 13-3/4"W x 2-1/4"H x 9-3/8"D. would be very greatful if someone could help me with this
  2. Aug 15, 2009 at 2:25 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Mine is under the drivers seat, different amp and a tight fit. Alpine 4 channel, forget the model no. but 75 watts per channel.
    Hope this helps.
  3. Aug 15, 2009 at 2:27 PM
    DBK4
    DBK4 [OP] Member
    California
    but can u still slide the seat back and forth without hitting the amp
  4. Aug 15, 2009 at 2:44 PM
    DBK4
    DBK4 [OP] Member
    California
    how did u mount it on the drivers seat
  5. Aug 15, 2009 at 2:49 PM
    DBK4
    DBK4 [OP] Member
    California
    did he just zip tie it to what whatever was under there
  6. Aug 15, 2009 at 2:57 PM
    DBK4
    DBK4 [OP] Member
    California
    yea i cansee how it is mounted now thanks man hopefully this will work
  7. Aug 15, 2009 at 5:27 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    If you amp runs particularly hot, then mounting it upside down can be an issue. Many are meant to radiate heat through the cooling fins. They are less effective when pointed down, due to heated air rising back around the amp.
  8. Aug 15, 2009 at 7:58 PM
    DBK4
    DBK4 [OP] Member
    California
    i like the under the seat idea but is there any others options i might have besides that i actually found a smaller more compact amp for way less
  9. Aug 15, 2009 at 8:23 PM
    KAPendley
    KAPendley Best Hack I Know
    Andy
    Hickory, NC
    96 2WD V6 Extended Cab
    Shaved, Lowered,Airbrushed (some)
    It's true, but it's not very common. Then of course, neither is mounting amps upside down. LOL
  10. Aug 15, 2009 at 8:24 PM
    oldtacomaguy
    Dave
    SE Conn.
    Seat works fine, that picture was taken with the seat all the way forward.
