Where is the engine temp needled supposed to sit at on 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by N2DesignsInc, Apr 28, 2018.
  1. Apr 28, 2018 at 12:54 PM
    N2DesignsInc
    N2DesignsInc [OP] --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Gentlemen, couldn't find an answer through search, but I'm sure it may vary from truck to truck based on environment, off-roading, incline, ambient temps outside, towing, but in general, where is your needle supposed to sit? Halfway? Just past?
  2. Apr 28, 2018 at 12:59 PM
    Bishop84
    Bishop84 Well-Known Member
    Half way or just past is perfectly normal.
  3. Apr 28, 2018 at 1:09 PM
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Right in the middle under normal conditions.
    DubfromGA likes this.
  4. Apr 29, 2018 at 6:41 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Mine's about 1/8" below half.
  5. Apr 29, 2018 at 7:10 PM
    N2DesignsInc
    Los Angeles, CA
    Sorry, that’s what I meant just didn’t know what it was tied too...
    tacoguy88 likes this.
  6. Apr 29, 2018 at 7:16 PM
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    pretty sure the coolant temp needle on these has a gimmick circuit to keep it dead center as long as its anywhere near normal range...
  7. Apr 29, 2018 at 7:17 PM
    SeeWhatHadHappenedWas...
    SeeWhatHadHappenedWas... Well-Known Member
    Jeremiah
    Oregon
    2017 OR DCSB MT Quicksand
    Get a scangauge 2, it is more precise. I seem to be between 185-200 degrees Fahrenheit at running temp. Another fun fact the high idle when it first starts doesn’t turn off till water temp hits 100 degrees.
    The-Stig likes this.
  8. Apr 29, 2018 at 7:20 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Semantics.
  9. Apr 29, 2018 at 7:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    See, that just proves there are a bunch of cheapskates in this thread. They only fill the temperature tank to half full. C'mon guys, it does not cost much at all to just fill it up to "H." I went to the temperature filling station today and had them fill 'er up. Perfect now, pegged full "H."
  10. Apr 29, 2018 at 7:23 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No, engine temps can 2X that in spots.
  11. Apr 29, 2018 at 7:24 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Mind sits dead center at operating temp.
  12. Apr 29, 2018 at 7:24 PM
    N2DesignsInc
    Los Angeles, CA
    H - High Speed, I'm on it.
    hiPSI[QUOTED] likes this.
  13. Apr 29, 2018 at 7:28 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    So what is the engine temp? The temp of the block in a specific spot? Oil temp? Exhaust temp?
  14. Apr 29, 2018 at 7:32 PM
    1bad2k
    Lone Star State
    2017 Tacoma TRD PRO
    Coolant.
  15. Apr 29, 2018 at 7:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Which is why they use coolant temp lol. Engines have multiple temperatures at specific locations. All those different temperatures are measured when calculating heat exchanger (radiator) load and sizing.
    Also coolant entering the heat exchanger is at a much higher temperature than the coolant exiting the heat exchanger.
  16. Apr 29, 2018 at 7:51 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I know, that’s kind of what I was getting at with the first post. Coolant temp is pretty much the industry wide accepted indication of engine temp. To say a guy needs to learn the gauge is coolant temp not engine temp is worthless since that is the only indication of engine temp (other than after the fact idiot lights) you get in most modern vehicle.
    DieselTech1 and hiPSI[QUOTED] like this.
  17. Apr 29, 2018 at 8:06 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Ya want it between 1/2 and 13/16 if it is working properly. Lower is not best, better that too high for sure, because too low and you introduce condensation into the oil.
    e6400ultra likes this.
  18. Apr 29, 2018 at 9:17 PM
    LeftCoastNerd
    08 AC 4x4 OR 6sp
    if you're just curious, and you're at all nerdy like I am, pick up a ELM327 bluetooth OBD module, stick it in your OBD port, and you can read the engine coolant temperature with TorquePro on any Android device. also read and reset diagnostic codes, etc etc.
    I have this one that seems to work well:
    https://www.amazon.com/gp/product/B00PJPHEBO
    https://play.google.com/store/apps/details?id=org.prowl.torque
  19. Apr 30, 2018 at 1:01 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    This is true. I monitor the coolant temp PID with OBD fusion and the dash needle will stay in the middle while the actual value fluctuates quite a bit. Normal.
    I suspect it is done this way to keep the average driver from worrying - ahhhh the gauge is normal and doesn't move, I feel good about that :lalala:. Hell, they don't even put numbers on it any more, because well - you don't really need to know I guess.
    Edit:
    Morning commute, 46F. 10 miles, mostly secondary roads @ 35-45 mph in 6th. A short stint on the highway at 60-65 followed by some stop and go. No WOT lol.
    Temp gauge reached normal/half way/straight up at 170 -175F, no movement after that. Coolant temp peaked at 199.
    I can't remember what the max coolant temp I've seen was (more than 205 IIRC), but the cluster gauge has never moved above straight up. We rarely see temps exceed 90C where I live BTW, the Atlantic Ocean has a lot to do with that.
  20. Apr 30, 2018 at 1:34 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Between C and H. :notsure:
