Where is the fuel filter located?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bisperfarm, Mar 31, 2023.
  1. Mar 31, 2023 at 3:07 PM
    Bisperfarm
    Bisperfarm [OP] Member
    Lynn
    White 2006 trd
    Where is the fuel filter on a 2006 trd prerunner
  2. Mar 31, 2023 at 3:10 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    It's part of the fuel pump assembly located inside the fuel tank.
    henryp, Bisperfarm[OP] and TnShooter like this.
  3. Mar 31, 2023 at 3:21 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    In Tank, all part of the fuel
    Pump assembly
    Unless something odd happened should not need to change that
    Bisperfarm[OP] likes this.
  4. Mar 31, 2023 at 5:13 PM
    Bisperfarm
    Lynn
    White 2006 trd
    Thinking some bad gas has affected it.
  5. Mar 31, 2023 at 5:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What are your symptoms?
    What makes you think it’s bad gas?
  6. Mar 31, 2023 at 5:30 PM
    Bisperfarm
    Lynn
    White 2006 trd
    Last night we had to put some gas in it from a gas can. The gas is not old but after we put the gas in we noticed a crack in the gas can lid. This morning, I made it about a mile and the truck died and won’t restart.
  7. Mar 31, 2023 at 6:18 PM
    caribe makaira
    Caribbean, Puerto Rico
    Squirt likes this.
  8. Mar 31, 2023 at 6:23 PM
    Bisperfarm
    Lynn
    White 2006 trd
    Thank you so much!
  9. Mar 31, 2023 at 6:30 PM
    TnShooter
    Deogee
    STOCK
    It would have to be a big crack to get enough dirt to clog the filter.
    By chance, did the can get left outside and water get in it?
    Dm93 likes this.
  10. Mar 31, 2023 at 6:34 PM
    Bisperfarm
    Lynn
    White 2006 trd
  11. Mar 31, 2023 at 6:36 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Disconnect fuel rail input, put hose into clear glass bottle, turn key to on(not start), fuel pump turns on and fuel goes into bottle, let bottle sit for a few minutes and see if it separates. Most likely guess would be it will separate and you will need to get the water out the gas tank.
    goforbroke123, super_white and henryp like this.
  12. Mar 31, 2023 at 6:37 PM
    Bisperfarm
    Lynn
    White 2006 trd
    We will try that tomorrow. I appreciate all of your help.
  13. Mar 31, 2023 at 6:39 PM
    joeyv141
    New Jersey
    Was the gas can full? How large is said gas can?
  14. Mar 31, 2023 at 6:40 PM
    Bisperfarm
    Lynn
    White 2006 trd
    5 gallon can, about halfway full
  15. Mar 31, 2023 at 6:43 PM
    joeyv141
    New Jersey
    Ok lets guess you added 3 gallons which is 1/7 tank capacity. Assuming you confirm there is water in your gas tank you may be able to fill the tank with fresh gas and put a large bottle of k100 in the tank, run the truck around the block/heavy idle till you burn up everything in the tank.
  16. Mar 31, 2023 at 6:44 PM
    caribe makaira
  17. Mar 31, 2023 at 6:44 PM
    Bisperfarm
    Lynn
    White 2006 trd
    Ok, well do that too.
  18. Mar 31, 2023 at 6:48 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Fuel pump does not run at key on on Toyota, you have to crank the engine or jump pins 3 and 5 of the C/OPN relay to make the pump run.
    Raylo and TnShooter like this.
  19. Mar 31, 2023 at 6:52 PM
    joeyv141
    New Jersey
    Ok good to know, appreciate it.
    I'd probably jump the relay then.
  20. Mar 31, 2023 at 7:02 PM
    caribe makaira
    Remove C/OPN and provide power to pin 3 only.
    TnShooter and Dm93[QUOTED] like this.
