Where is the fuel filter located?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bisperfarm, Mar 31, 2023.
  1. Mar 31, 2023 at 10:00 PM
    bikerx
    bikerx Member
    Vancouver BC
    did it feel like it was misfiring or did it just randomly turn off? I ask because i was driving down the a fire service road just cruising then all of a sudden my engine turned off. I pulled over and tried to turn it on and it would just crank . Checked the efi fuse/efi fuse and what not but couldnt get it to fire. it would just crank.
    Towed it home and i tried swapping around the relay for the C/OPN with the horn relay and it fired right up. Worth a try before you get too deep into things.
    https://www.youtube.com/watch?v=QMH8P-IucVw&ab_channel=LehewTech
    this guy actually has a video about it lol.
  2. Apr 1, 2023 at 7:47 PM
    Bisperfarm
    Bisperfarm [OP] Member
    Lynn
    White 2006 trd
    I just shut of, no misfire
  3. Apr 1, 2023 at 9:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did the fuel gauge show that there was gas in it when it ran out the first time?
  4. Apr 1, 2023 at 9:27 PM
    Bisperfarm
    Lynn
    White 2006 trd
    Fuel light was on there showed a very small amount of gas (not quite on empty yet).
  5. Apr 1, 2023 at 9:29 PM
    TnShooter
    Deogee
    STOCK
    At his point does the truck just crank?
    Or does it start and then immediately die?
  6. Apr 1, 2023 at 9:33 PM
    Bisperfarm
    Lynn
    White 2006 trd
    It cranks, doesn’t start. Today, sprayed starter fluid, it started then immediately died. Disconnected the fuel line, tried to start it and fuel did come out of the line. We have determined that the fuel pump is ok and the problem must be with the gas. Tomorrow, we will try to drain the tank and put fresh gas in it.
    TnShooter likes this.
  7. Apr 2, 2023 at 4:32 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Did you confirm there is water in the gas tank?
  8. Apr 3, 2023 at 5:54 AM
    Bisperfarm
    Lynn
    White 2006 trd
    Yes, confirmed that there was water. Tried to drain the fuel but that didn’t work. Added fresh new gas and a bottle of “heet” because no one had any k100. Yay, it worked!
    TnShooter and joeyv141 like this.
  9. Apr 3, 2023 at 5:54 AM
    Bisperfarm
    Lynn
    White 2006 trd
    Thank you everyone for your help!!!!
  10. Apr 3, 2023 at 6:36 AM
    joeyv141
    New Jersey
    Congrats on doing your diag correctly, I would drive it locally till the low fuel light comes on then fill it up again along with some more additive just to make sure any water is flushed out.
    Bisperfarm[OP] likes this.
  11. Apr 3, 2023 at 7:06 AM
    Bisperfarm
    Lynn
    White 2006 trd
    That is the plan. Thank you again.
    joeyv141 likes this.
