Where is the Hood Insulation?
Discussion in 'General Automotive' started by Sixfeathers, Apr 1, 2011.
  1. Apr 1, 2011 at 6:32 PM
    Sixfeathers
    Sixfeathers [OP] Well-Known Member
    Kreg
    Maryland
    2011 Access Cab
    Led lights: Replaced Bulbs in front,Fog Light modification, Westin Nerf Bars, TS mod,
    Why is it that all other manufacture's of vehicles use insulation attached to the underside of the hoods and I haven't seen a new truck on here with one? Seems like it would absorb the road and engine noise. Any ideas on this?
  2. Apr 1, 2011 at 6:37 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    that's his question I think... "Why" isn't there one? :notsure:
  3. Apr 1, 2011 at 6:45 PM
    ColtsTRD
    Scott
    AZ
    will that stand up to the heat under the hood?
  4. Apr 1, 2011 at 6:53 PM
    Sixfeathers
    Kreg
    Maryland
    2011 Access Cab
    Well go figure. That is why I was asking the question? Do you not find that odd?
  5. Apr 1, 2011 at 6:59 PM
    Sixfeathers
    Kreg
    Maryland
    2011 Access Cab
    My Charger has one that is like some sort of composite or maybe more of a plastic felt. I was just curious. I was under my hood this morning and I just wondered if mine was missing. I know they put them on the first generation trucks.
  6. Oct 15, 2012 at 7:09 AM
    old tacoma man
    old tacoma man Member
    2011 reg cab 4x4
    tri fold tonno cover, rubber bed mat, step bars, shorty anntena, 17"chrome wheels, fog lights
    i was looking for some under hood insulation came across product at jegs.com has a universal hood insultation looks good might try ! Anyone ever use this ????
  7. Oct 15, 2012 at 7:18 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    As far as I understand the hood insulation is NOT for sound purposes. If it was to quiet things down it would be made out of a very dense material like mass loaded vinyl. However, it's actually made out of fiberglass in most cases I'm pretty sure.
    I'm pretty sure it's only purpose is to smother engine fires. The plastic pins are supposed to melt so it falls onto the engine allowing the passengers additional time to get out of the car.
  8. Oct 15, 2012 at 7:18 PM
    ItalynStylion
    Steven
    DFW, Tx.
    So maybe Toyota was like, "Yeah.....our engines don't catch fire."
  9. Oct 15, 2012 at 7:29 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    :eek: Looking back at the OP's past posts i can see how he might have been banned! :rofl:
