Where is the ICV located?
Discussion in '4 Cylinder' started by bimmerman, Jun 25, 2011.
  1. Jun 25, 2011 at 1:45 PM
    bimmerman
    bimmerman [OP] New Member
    CA
    96 Tacoma
    I was wondering where the idle control valve is located on the 96 Tacoma 2.4L
    4 cylinder? Thanks
  2. Jun 25, 2011 at 2:08 PM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
  3. Jun 25, 2011 at 2:10 PM
    bimmerman
    CA
    96 Tacoma
    Thanks man! I asked this because my idle is very ruff and mostly wont want to idle at all so any help is much appreciated.
  4. Jun 25, 2011 at 2:20 PM
    mjohn617
    Petaluma, CA
    Haha, beat me to it...
    A heads up Bimmerman, most your info for maint. is at the top: Mod & Tutorials
    If your having problems with using the search function, there is a write-up explaining different ways to help you use wildcards and filter functions.
  5. Jun 25, 2011 at 2:28 PM
    bimmerman
    CA
    96 Tacoma
    Ok I will give this a try, thank you very much for your help!
  6. Jun 25, 2011 at 6:13 PM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    Not sure if it's the same with yours or not but on my 93, if you look to the left of the engine there's a little screw. The vibrations seem to loosen the screw for me then the ride gets rough. But if I tighten it too much, it will stall when I push in the clutch. Pretty sure it controls the air fuel mixture.
