Where is the O/D and how to kick it out? - 2008 Tacoma V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skj, Feb 28, 2012.
  1. Feb 28, 2012 at 8:09 AM
    Skj
    Skj [OP] New Member
    I have a 2008 Tacoma V6. It is a different type of vehicle that I am used to compared to a Dodge / Ford / Chevy. I might be old school, but the O/D was located on the steering column (P, R, N, D, OD, etc...) or a button to press on the shifter.
    This 2008 4 door V6 Tacoma has a shifter in the console with P, R, N, D, 4-D, 3-D, 2, D. Where I place the shifter to kick it out of Overdrive or In Overdrive?
  2. Feb 28, 2012 at 8:13 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Place it in 4th instead of D. Why would you want to kick it out though?
  3. Feb 28, 2012 at 8:14 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Put it in D and forget about it. If you're towing really heavy and it seems to be hunting for gears at speed, drop it to 4 so it can't shift to the 5th gear. No O/D button like your older vehicles had.
    welcome to TW :cheers:
