Where is the oil cooler?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04tacoma trd, Dec 9, 2017.
  1. Dec 9, 2017 at 7:06 PM
    04tacoma trd
    04tacoma trd [OP] Well-Known Member
    So, I am ready to order my ebay OEM parts kit for the cam timing belt replacement and it turns out there are two styles of water pumps - one for 3.4 L engines with an oil cooler and one without. My understanding from asking around is nearly all of the 3.4 L engines have the oil cooler, so where in the heck is this thing located? How can I tell if my truck has one? Wouldn't it be up front near the radiator to get some cooling air flow? Well, I don't see one.
    DustStorm4x4 likes this.
  2. Dec 10, 2017 at 2:08 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Round domed canned looking thing with 2 hoses coming out of on the drivers side of the block.
  3. Dec 10, 2017 at 3:11 AM
    tony2018
    tony2018 Well-Known Member
    Man, whoever put the clamps on them the first time didn't think things through. Had a hard time getting to them.
  4. Dec 10, 2017 at 3:17 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Is that your block? Looks very clean
  5. Dec 10, 2017 at 9:32 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    No. Pic off internet.
  6. Dec 10, 2017 at 1:57 PM
    04tacoma trd
    So, that is what that thing is! All these years. Now I know. Thanks
  7. Dec 11, 2017 at 4:45 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Huh, I never knew this, will have to check mine and see if it has one now that I'm curious.
  8. Dec 11, 2017 at 4:46 PM
    tony2018
    There's an o-ring behind it. Best take a look at it and replace it, along with the coolant hoses that run to the water pump.
  9. Dec 11, 2017 at 5:13 PM
    04tacoma trd
    I already ordered new upper and lower radiator hoses, but now that I know about this, I think I will order the two hoses related to the oil cooler, too (15778-62030 and 15777-62020).
  10. Dec 11, 2017 at 5:23 PM
    tony2018
    The o-ring..
  11. Dec 12, 2017 at 3:44 AM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Is this a maintenance item mine is getting up there in miles 260k should I buy a new oil cooler? Maybe just swap hoses and the o-ring? Thanks.
  12. Dec 12, 2017 at 1:35 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    The hoses are a maintenance item
    The cooler it self is a as needed. If it leaks coolant or oil. Or if you get oil in the cooling system. 260k on mine with no problems.
    Luv my yota[QUOTED] likes this.
  13. Dec 12, 2017 at 2:18 PM
    Luv my yota
    00 turd lift 33's
    Ok mine doesn't leak but those hoses should go, along with the o-ring then. I did get coolant in my oil for a bit, but caught it before it completely ruined my oil and my main bearings are ok should I replace it anyway? My intake manifold was leaking coolant into the heads, after swapping manifold gaskets it picked up power. Just wondering if that oil cooler could have took a dump, but my scanner doesn't show temps out of normal.
  14. Dec 15, 2017 at 3:34 PM
    1997tacomav6
    Denver
    If you peek between the inner wheel well and the rubber skirt on the drivers side you will see if you have one on the block. All these years and never knew I had one or where it was till I replaced
    the rubber skirt inside the wheel well, hehe
    It's under the exhaust manifold so you don't see it from up top
  15. Dec 16, 2017 at 12:46 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Maybe these videos will help you out. Be sure to watch Part 2 for an easier way to get the timing belt on and other helpful info. Also be sure to read the video descriptions for more helpful tips and additional information.
    https://youtu.be/vHC46ypHxWc
    https://youtu.be/mErd7xoBS9I
  16. Dec 16, 2017 at 2:43 PM
    04tacoma trd
    Maybe it is in part 2, but I watched part 1 awhile back and they couldn't figure out how to get the new belt on.
  17. Dec 16, 2017 at 3:07 PM
    Timmah!
    TIM
    Well, we actually figured it out in the first video but show a much easier way in the second video.
    crakumskull likes this.
