Where is the plug in for trailer brake under dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tfeltz73, Jun 30, 2013.
  1. Jun 30, 2013 at 10:38 AM
    tfeltz73
    tfeltz73 [OP] That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    My truck is suppose to have the towing package but I just spent 30 min under the dash trying to find the plug in for the trailer brake. If someone could please show pictures of where it is would be awesome. I have to pick up my new camper tomorrow and need it for taking it home, thanks.
  2. Jun 30, 2013 at 11:03 AM
    A3umph
    A3umph Well-Known Member
    outside of KCMO
    '12 Tacoma Access Cab TRD OR
  3. Jun 30, 2013 at 2:06 PM
    tfeltz73
    central Wisconsin
  4. Jun 30, 2013 at 2:35 PM
    tfeltz73
    central Wisconsin
    I just looked at my dads tundra and his is right in the open and my Tacoma doesn't have that plug in but it has the towing package, so now what
  5. Jun 30, 2013 at 4:04 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    did it come with the pig-tail for wiring to your trailer-brake controller (should be in glove box)? if not then maybe you don't have a factory tow package.
    I had the same problem with my truck, it has the factory light wiring, the Toyota receiver, but nothing else. I assume it was dealer installed instead of factory equipped. mine is a base model though, which I understand cant come factory with tow package.
  6. Jun 30, 2013 at 4:15 PM
    chris5255
    chris5255 Me mber
    Renton WA
    12 Tacoma DCLB TRD Sport-'07 FJ Cruiser
    BAMF Sliders Fog light switch mod, Pelfreybilt Front bumper, Warn Zeon10 winch pinstriping for speed
    It took a tech at my local dealer 30 minutes to find mine. He had to pull the plastic kick piece down by the drivers left foot. He found it bundled(taped) together with some other wires. Once he cut the bundle open it was obvious.
  7. Jun 30, 2013 at 4:20 PM
    cooktaco
    cooktaco Well-Known Member
    Northern California
    11 Dbl. cab TRD 4x4
    Weahertecs, Bed met, Snugtop, Avid sliders, TSB Springs, Bilstein 5100's @1.75,
    Stick with it, it's there. Mine was also tucked in and taped to another wire bundle. Took me an hour to find it with a couple of long breaks to stretch out my back due to laying under the dash with a flashlight for so long. Good luck.
  8. Jun 30, 2013 at 4:44 PM
    smd3
    smd3 Well-Known Member
    You will never see the plug, you have to feel for it behind a bunch of wires. You'll feel the plug end flopping loose, give it a tug and it'll pull free pretty easily giving you about 6 inches of slack.
  9. Jun 30, 2013 at 4:55 PM
    tfeltz73
    central Wisconsin
    I found it, it was way up under the dash behind a group of wires where you couldn't see at all, thanks for every ones help. It took a few seconds to hook up after I found it
  10. Jun 30, 2013 at 5:53 PM
    Tao Zero
    Tao Zero Well-Known Member
    I must have gotten lucky, mine was out in the open. Albeit tucked up in there. Toughest part was connecting the two plugs with one hand.
