where is the thread for adding heated mirrors with indicator and puddle light ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by No Shoes Nation, Jan 10, 2021.
  1. Jan 10, 2021 at 1:07 PM
    No Shoes Nation
    No Shoes Nation [OP] Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Too many threads on here, where is this one?
    Let me be more specific, I have mirrors, need parts list of switch, relay etc so I can fab my own harness.
    Thank you.
  2. Jan 10, 2021 at 1:29 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
  3. Jan 11, 2021 at 9:08 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    I did this mod last year. There are a dozen good write ups on here and that is why I didn't do mine. I made a harness and used a timed relay that I found through one of the write ups here (I have tried to remember and cannot as well as look it up for you-sorry.) job is time intensive but easy. If you have specific questions let me know. I used:
    2013 4Runner mirrors swapped to 2015 Tacoma perches to get heat, signal and puddle
    Truck was wired for turn signals so tapped that harness as well as mirror adjustment
    Created harness for heat and puddle
    All wire was 18g.
    LitFuse likes this.
  4. Jan 11, 2021 at 9:37 AM
    No Shoes Nation
    hey good to hear from you on this.
    I am now getting parts together to do this mod.
    I have complete mirror assemblies with heat, turn and puddle.
    Looking for info on best switch and if needed what relay to use.
    Looking for wiring diagram to make it all work.
    I can easily put all this together, just need to know what to use and how to do it. I have plenty of time as I am working from home.
    I have dug up some info on here but if I could get a condensed version it would really stop me from going totally insane with this.
    Thanks to all for any and all help.
  5. Jan 11, 2021 at 3:23 PM
    pearing
    Wisconsin
    2015 SR5 quadcab
    The switch I used came from Air on Board:
    Professional Designer of Rocker Switches and Switch Panels -Air On Board
    Some have tried the Highlander switch but I could not stomach the cost. It has the delay built in if I am not mistaken
    I found the manufacturer of the relay-Wolsten Tech:
    TDRx Automotive Time-Delay Relay (wolstentech.com)
    I would call or send an email-that is how I got the correct one for my application and switch. You will need a relay.
    What mirrors are you using? I never found mirrors that did it all that had the correct door perch mount... Like I mentioned above, my truck had the harness for the turn signals-I just modified the mirror to make that and the mirror adjust part work. For the other I ran two sets of two wires out through the doors on each side. It is easier if you pull the existing gasket and feed everything through. Oh-you will have to disassemble the door panels to get at all this stuff. All the wiring took me most of two days.
    Good luck!
