Where is the VSS located?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Jun 11, 2013.
  1. Jun 11, 2013 at 8:36 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    I am trying to find my VSS (Vehicle Speed Sensor) on my 3rz 5 speed
    I am trying to wire in a yellow speed box calibrator and cant seem to find it?
  2. Jun 11, 2013 at 11:08 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    The VSS can be traced behind the glove box
    and is in the primary harness leading to the cpu
    you could tap in there and run less wire.
    I used the Dakota Digital... but for the 5vz
    but would think the YB could be installed similarly as well. ^ Check the wiring schematics first...
    as the 3rz could be somewhat different. :notsure:
    here's the more traditional method...
  3. Jun 12, 2013 at 5:09 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    I have seen those i did search before posting. My problem is i have been looking all around my t-case and transmission and i cant find the damn plug! i was hoping yellow box had a plug and play kit. So i email one of their reps and was told that there are 2 different types of VSS in our trucks.
    A 3 wire sensor
    and a 2 wire sensor
    so:
    1. I am trying to figure out which one i have
    2. trying to figure out where it goes so i can wire it in the glove box.
    in scubas case on TTORA he had a 3 wire VSS which means Yellr Box offers a plug and play! and all his wiring was unnecessary. Just trying to get the right setup ordered. I have the FSM but for the life of me cant find it in that massive 1700 page document.
    Here is a picture of what i think should be the VSS but it looks nothing like the reference pictures i have been looking at:
  4. Jun 12, 2013 at 5:56 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Yeah that would be a cable op speedo. So the only way to change the ratio would be to pull the rest of the assembly out of the T-case and replace it with one with less/more gear teeth. Get your money back for the yellow box thingy.
  5. Jun 12, 2013 at 6:20 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So mine is mechanical and every other Tacoma uses a sensor? i feel like that's not right there has still got to be a way.
  6. Jun 12, 2013 at 6:36 AM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    ok then...good luck hooking it up
  7. Jun 12, 2013 at 7:46 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    the problem is my speedo is off by like 21% so simply changing the internal gears will not be enough to make the correction.
    Do i have any other options?
  8. Jun 12, 2013 at 8:47 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    here are some of the FSM pages in the transfer case section, these are for the 5speed 3rz, so unless im crazy i do have this sensor somewhere.
  9. Jun 13, 2013 at 11:12 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Looks like your right FordLess...follow the cable into the firewall. so unless it gets converted to a digital analog or whatever signal behind the dash (which i doubt it does) it seems i am shit out of luck. This sucks is there no way to fix this? like i said before my percentile difference is too large to be corrected by a speedo gear swap, unless someone makes custom speedo gears?
  10. Jun 13, 2013 at 11:32 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
  11. Jun 13, 2013 at 2:38 PM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Glad u got it figured out
    Oh and why not just use the guy he used. Just call him and tell him what you've got and see if he can build it and ship it to you.
  12. Jun 13, 2013 at 6:03 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yeah that could work, he doesn't have a website and im not local so im iffy about transactions like that.
  13. Jun 14, 2013 at 6:11 AM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    You gotta put a little faith in people sometimes
  14. Feb 9, 2023 at 11:47 AM
    cb2xs
    cb2xs Active Member
    Jeffrey
    2005 Tacoma Double cab
    Wolfgang 123, have you found the Vehicle speed sensor? I know there are sensors on each wheel and two on the transmission, driver side and passenger side near the drive shaft. I'm looking VSS sensor A and with all the research I have done, it's located somewhere in the Instrument cluster.
  15. Feb 9, 2023 at 11:52 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    10 year thread revival...this is the 1st gen forum. Wolfgang 123 was last seen on here about 2 years ago.
    Bivouac likes this.
  16. Feb 10, 2023 at 5:29 PM
    cb2xs
    cb2xs Active Member
    Jeffrey
    I have posted my problem about the VSS Sensor A before, but no one seems to know where it's located. I've read that it's located in the Instrument Cluster, but Tach, Speedometer plus the other gauges are working. Only the cruise control is not. I found online that I would have to remove the air filter and intake to find it.
    I have used a tracer, located the Red/yellow wire for the sensor but it led me down to the trans.
    Anyone?
  17. Feb 10, 2023 at 5:35 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
  18. Feb 11, 2023 at 11:57 AM
    cb2xs
    cb2xs Active Member
    Jeffrey
    I did check the trans and changed both driver and passenger side sensors. Still looking for the VSS sensor "A", which seems to be in the instrument cluster. Or it may be on top of the bell housing of the trans. Maybe.
  19. Feb 11, 2023 at 12:46 PM
    Kwikvette
    Kwikvette Chief Executive Officer at Kwik Fab
    Stock
    You're not only bringing up a 10 year old thread, you have a different generation truck.
    Bivouac and Taco critter like this.
  20. Feb 11, 2023 at 9:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Let me guess?
    You are chasing a p0500 code?
    cb2xs[QUOTED] likes this.
