Where is this junction point for the turn signals? Pic included
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caligula, Aug 5, 2015.
  1. Aug 5, 2015 at 5:02 AM
    Caligula
    Caligula [OP] Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Cant find much of a description to where the junction points for the front turn signals are other than:
    1A Cowl WireandJ/BNo.1(LowerFinishPanel)
    1C 1F Engine Room Main Wire and J/B No.1 (Lower Finish Panel)
    Help please. Location im looking for is circled in red. The goal is to wire an inline diode then have a capacitor/relay combo to switch the turn signals from always on to flashing with the rest of the turn signals.
  2. Aug 5, 2015 at 10:56 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    sorry to say but that gray box is the ECM
    your going to have to figure out how to do it before or after that junction
  3. Aug 5, 2015 at 11:06 AM
    Caligula
    Los Angeles, CA
    I don't think it's the ecm, the turn signals wouldn't pass through that. Maybe a body control module? The manual mentions 'lower trim panel' and 'junction box 1'. I can't figure out where that is.
  4. Aug 5, 2015 at 11:18 AM
    keakar
    karl
    louisiana
    you would be surprised what goes through the ECM, the door locks are run by the ECM and it also runs the chimes for headlights and lock or unlock the doors depending if the key is in the ignition.
    everything else is there so all I can think of that it might be would be the ECM but who knows?
  5. Aug 5, 2015 at 11:21 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    are you trying to make the parking lights flash with the blinkers?
  6. Aug 5, 2015 at 11:36 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The gray shaded box is just a portion of the main in cab, fuse/relay/junction block on the driver side behind the dash.
    Nice and tight back there with a bunch of other wiring.
  7. Aug 5, 2015 at 11:56 AM
    Caligula
    Los Angeles, CA
  8. Aug 5, 2015 at 11:58 AM
    Caligula
    Los Angeles, CA
    Well, it wouldn't be the first tight place ive had to get into...
    Think its partially removable without taking the upper black dash out? Id like to do what im going for without cutting into the factory harness.
  9. Aug 5, 2015 at 12:20 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    It might be possible. Should be more apparent when you find the exact location of the wires in question, on/in the panel. There is a bunch of other wiring in the same bundle/s.
