Where is this plug!?
Discussion in 'Technical Chat' started by memario1214, Apr 3, 2013.
  1. Apr 3, 2013 at 5:36 PM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  2. Apr 3, 2013 at 5:46 PM
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    404 not found
  3. Apr 3, 2013 at 5:52 PM
    memario1214
    Colton
    Missoula, MT
    Dammit. try it again
  4. Apr 3, 2013 at 6:01 PM
    05taco2.7
    05taco2.7 Well-Known Member
    JIMSTER
    omaha nebraska
    Soon to come
    should be on the fuse block behind the change cup deal in front of your left knee below the switches
  5. Apr 4, 2013 at 9:27 AM
    memario1214
    Colton
    Missoula, MT
    It is the T1 plug if that helps anyone... ripped my fuse block apart and unfortunately found nothing. It seems to me that its under the hood somewhere...? Is there another layer of stuff under the underhood fuse block?
  6. Apr 4, 2013 at 9:50 AM
    Turbomeister
    Turbomeister Member
    Missouri
    09 AC V6 AT TRD OR
    DTRL Switch Mod Pioneer DEH-7800BHS
    No, I don't believe it's under the hood. Like the previous poster said, pull out the little flip-down drawer by the driver's left knee. There is a fuse block in there behind the dash. There's all kinds of stuff plugged into that fuse box as it contains the Body ECU running lots of interior lights, blinkers, DTRL, etc. Although I believe to get any real access to any of those plugs you'll need to pull the lower dash off to give you some room...fun fun :rolleyes:
    Some of the plugs are actually on the back of that box (towards the firewall) if that helps. Just pull the dash, unscrew the three (I think?) bolts holding it in, and pull it out. I think you'll find it.
    I've been in there before to mess with the DTRL. Burned up my Body ECU and need a new one.....no DTRL or blinkers anymore! :eek:
