Where is tranny oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanGer, May 18, 2009.
  1. May 18, 2009 at 12:01 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    On my '07 manual, I am looking for the transmission drain and fill. Can anyone help?
  2. May 18, 2009 at 12:33 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Yes. Don't.
    It's a sealed tranny and needs to go to a mechanic to be filled. Draining's the easy part. But filling...
  3. May 18, 2009 at 12:49 PM
    mikey05
    mikey05 Member
    05 DC Shortbed
    Too many to list
    It is not too hard to change the transmission fluid on an 05 standard as I have done it. If your 07 tranny is anything like the 6 spds then they are there the fill is on the driver side in an odd spot just have to look real good.
  4. May 18, 2009 at 12:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    He has a manual.....;)
  5. May 18, 2009 at 1:04 PM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    From what I remember doing my 6spd over 2yrs ago (think same for your 5spd)... 24mm socket. Crawl under tranny, drain bolt on underside, fill bolt facing drivers side. Loosen FILL BOLT first. On the Quart bottles, I used a hand pump w/ a hose ext. Was a little tight in there, but if you got it lifted up, gives you better access.
  6. May 18, 2009 at 1:05 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    You're the last person who should be giving fluid advice on our trucks.
  7. May 18, 2009 at 1:21 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Here is a diagram for the R155F (5 speed 4x4 manual trans.)
    When you fill the transmission up with oil again, fill it to where the oil is just a hair under the fill plug. The manual calls for 0-5mm from the drain plug.
  8. May 18, 2009 at 1:22 PM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    I was told it was a sealed transmission on my 2006 DC Auto... and that it didn't need it.
  9. May 18, 2009 at 1:24 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    You're alive???? :eek:
    the auto won't need service for 100k(?) miles, he has a standard
  10. May 18, 2009 at 1:24 PM
    SC4333
    Grant
    San Antonio, TX
    The automatics are sealed, while the manual trasmissions are not.
  11. May 18, 2009 at 1:27 PM
    Agent475
    Waldorf, MD
    2006 Red TRD Sport
    I am!
    Thanks for the info...
  12. May 18, 2009 at 1:27 PM
    TacoNut
    Adam
    Denver, Co
    Good to see you back around!
  13. May 18, 2009 at 1:28 PM
    Agent475
    Waldorf, MD
    2006 Red TRD Sport
    Thanks... yea, I was laying low for a while... work stuff.
  14. May 18, 2009 at 2:55 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    lmaooooooooo... Pwned! :d
  15. May 18, 2009 at 3:54 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Here's an idea asshat. It's called get stuffed.
  16. May 18, 2009 at 4:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think he was meaning it as a joke man. relax.:)
  17. May 18, 2009 at 4:02 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    If that's the case then I apologize. I've been pretty tense as of late. My exboss is screening my calls and essentially refusing to give me my last paycheque.
  18. May 18, 2009 at 4:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i believe i'd be paying my ex boss a visit..........and taking my last pay check!!! that shit aint cool.
  19. May 18, 2009 at 4:12 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    At my last job, I got my last ckeck about a week after I stopped working. Then about two weeks later, got another check. :confused:
    I didn't complain.
    Anyways, back on topic:
    Good luck changing your fluids. :D
  20. May 18, 2009 at 8:06 PM
    DanGer
    btw I figured it out. Thanks a bunch guys. If you wanna see the end product look in the 4 cyl section
