Where NOT to use anti-seize compound....?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crow Horse, Mar 2, 2021.
  1. Mar 2, 2021 at 2:15 PM
    Crow Horse
    Crow Horse [OP] Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Yes, ears, hair, face, man land,.....you name it, it's left it's mark.....
    steelcity2 and badger[QUOTED] like this.
  2. Mar 2, 2021 at 2:20 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Anyone remember the ol' Brylcreme commercials???? "Just dab will do ya!"
    steelcity2 likes this.
  3. Mar 2, 2021 at 3:14 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Now we're really dating ourselves......Sadly I do remember....
  4. Mar 2, 2021 at 3:20 PM
    Knute
    The point........a little is too much.
    Be stingy with the anti-seize. Try to clean your finger after each application, then try not to touch anything. It does have a tendency to migrate onto everything. Latex or nitrile gloves make cleaning your fingers a bit easier.
    Above all, DON'T touch yourself or your dingus...........
    SR-71A and Crow Horse[OP] like this.
  5. Mar 2, 2021 at 3:30 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    I have filled syringes with it for more precise applications with better results but it still manages to find ways onto other things where it has no place being.
    Another mystery, why is the brush always too short for the container?
  6. Mar 2, 2021 at 3:51 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Marketing strategy
    SR-71A likes this.
  7. Mar 2, 2021 at 3:56 PM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    Great explanation. I remember jeep useing New Process Gear transfer cases with magnesium cases. They required special washers to keep the steal bolts from touching the case. They were a caged type washer. You didn't want to leave thoughs out. Rust is much easier to deal with than galvannic corr.
  8. Mar 2, 2021 at 4:04 PM
    Scott W
    Scott
    Saranac Lake, NY
    That I can deal with. Non-moving mating surfaces. And a small thin coat. It has no viscosity properties for moving or sliding components. I can't emphasize a small thin coating enough. The shit gets everywhere. I refer to it as "never-sleeze".lol
  9. Mar 2, 2021 at 4:16 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I use Red N Tacky on my skid plate bolts, my center hubs where they fit in the wheels and I even put a light smear on my lug studs on occasion. I spray WD-40 into my lug nuts to keep my nuts from swelling.
  10. Mar 2, 2021 at 4:22 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  11. Mar 2, 2021 at 4:24 PM
    Markcal
    Markcal Well-Known Member
    I remember not finding my splash shield on my previous truck that went into the shop for service after a few bolts broke off from rust. One of the first things I did was coat my new Tacomas splash shield bolts with anti-seize. Recently I need to remove the SS after about 10 years living in the rust belt and it made a world of a difference removing those bolts.
    I had a garden last year and wanted to use two metal stands that had a wide base the metal pole was secured to using a bolt, it was sitting outside for a few years and I expected the bolts to be seized to the base with rust, thinking it would be a bear to free-up, if not impossible, but lucky the previous owner was smart enough to put a little dab of anti-seize on the treads the last time he stored it, which made my day because it was like butter removing the bolt, and saved me a lot of aggravation fight with it.
  12. Mar 2, 2021 at 4:27 PM
    Markcal
    Red N Tacky is great stuff, so great I bought a case of the grease for my zerks and will be used in place of the Mobil 1 grease in the future.
    winkel[QUOTED] likes this.
  13. Mar 2, 2021 at 4:46 PM
    badger
    badger Well-Known Member
    07 SR5
    I never use the brush in the can. It's always too loaded. I use an acid brush and toss it when I'm done.
  14. Mar 2, 2021 at 5:08 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Do your nuts tend to swell most when lowered into saltwater? Mine do.
  15. Mar 2, 2021 at 5:15 PM
    #35
    Knute
    I quit buying the cans......too messy....and the brush OMG, talk about a smear-o-matic........
    I buy the little squeeze tubes. Much neater. I can just squeeze a small dab onto the threads.
  16. Mar 2, 2021 at 5:28 PM
    #36
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Fluid Film or Cosmoline - most fasteners, hub to brake rotor hat, brake rotor hat to wheel
    Anti-seize - areas too hot for Fluid Film e.g. spark plug threads, O2 sensor threads
    Grease - splines e.g. where CV axle mates with front hub, steering shaft mates with steering wheel
    Silicone spray - electrical connector rubber seals, O-rings
    Where a torque wrench is used, I reduce the torque to 60-65% of book value.
    The only thing I install dry is lugnuts. Corrosion hasn't been an issue with fully enclosed lugnuts.
  17. Mar 2, 2021 at 5:32 PM
    #37
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    winkel, SR-71A and Jimmyh like this.
  18. Mar 2, 2021 at 7:09 PM
    #38
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
  19. Mar 2, 2021 at 7:36 PM
    #39
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    What’s rust?
    3JOH22A likes this.
  20. Mar 2, 2021 at 8:00 PM
    #40
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Same question asked by Toyota engineers apparently...
