Where shall I place my TEQ decal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Usethe2nd, Aug 8, 2015.
  1. Aug 11, 2015 at 6:51 PM
    Usethe2nd
    Usethe2nd [OP] Well-Known Member
    Justin
    Fall city
    Welded metal
    Wish I woulda known this before I ordered!
  2. Aug 11, 2015 at 7:21 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Wait! So if I wanted a smaller one, you can do that?
