where should I get front brake pad service in Los Angeles?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mr Tacoma, May 11, 2024.
  1. May 11, 2024 at 4:12 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    My math for a PROPER brake job at an independent shop:
    $100 for pads (includes 10% markup for sourcing & tax)
    $200 for rotors (ditto)
    $50 for two bottles of brake fluid and one can of brake cleaner (ditto)
    $400 for labor (about 2.5 hours depending on prevailing hourly rate)
    $750 all in
    YOU GET WHAT YOU PAY FOR.
    Slapping brake pads on a 3rd gen Tacoma is most definitely NOT proper maintenance.
  2. May 11, 2024 at 4:31 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Lol! That should pair well with your $300 oil change. Come by my shop any day, I would really appreciate your business.
  3. May 11, 2024 at 4:31 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    No dealer is going to just slap on brake pads they will cut your existing rotors or if needed replace them.
  4. May 11, 2024 at 4:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The brake pad only price is just to get you in the door and your vehicle on the rack with the wheels off.
    After they take a few things apart you'll get a phone call - "oh by the way, the rotors are too thin to resurface, we need to replace them". By the time you get your truck out of there it's the same price as everybody else
    If I tried that I would get Yelped into oblivion. Everybody and their mother knows it's going to get rotors too. It's just reputable independent shops have to be upfront about it and dealerships can pretend like they're going to pad slap it just to get you in the door
    Chew likes this.
  5. May 11, 2024 at 4:53 PM
    BigCarbonFootprint
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    My only other comment here is that the practice of "re-surfacing" brake rotors is becoming obsolete. If it hasn't already.
    By the time one considers the time and effort to put used, warped, out of round, out of balance, brake rotors on a lathe machine, and mill them to within OEM balanced specification (which is often times not possible after the fact) it is simply less expensive to buy new ones in the first place.
    As a final point, many shops simply don't want the liability or hassle. Or the space it takes for the lathe machine on their shop floor which can be put to far better use.
  6. May 11, 2024 at 5:01 PM
    BigCarbonFootprint
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    Nah, no thanks. My numbers above are solid and realistic. Maybe you or your shop tech(s) can swap brakes around on both front wheels in an hour. Or get parts for less. That's certainly possible. Everything torqued to spec. Road tested. Brakes bedded.
    And nobody is paying $300 for an oil change.
  7. May 20, 2024 at 6:12 AM
    MikeMcfly
    MikeMcfly Active Member
    Alpharetta, Ga
    2019 Taco
    Came in as I needed an oil change $60 which is needed then saw I needed front pads $289 I am using their website to post this. Ha
